Banned
Send a message via AIM to prebordao Send a message via Yahoo to prebordao Send a message via Skype™ to prebordao
Why is the oil light green ?
Yesterday, it ocurred to me... why make the low pressure oil warning light GREEN ?!
Everybody does it red...
Old 05-30-2013, 09:27 AM
skinnerd's Avatar
So you don't get it confused with the red alternator light that usually signals a broken fan belt.
911's are different from water cooled cars in the regard...they're air cooled and the fan belt is a "critical" component in the health of your engine.
Porsche wanted you to know immediately which problem you had.
Either a broken fan belt (red light) or low oil pressure (green light).
If both lights were red, you'd have to investigate further.
As simple as that....
"Are you out of your Vulcan mind?"
Doug
2022 Carrera 4S, 1989 Delta Integrale, 1973 911T CIS
Old 05-30-2013, 09:55 AM
Banned
ok, so red =highest priority, green=lower priority
hmmm
Old 05-30-2013, 09:59 AM
skinnerd's Avatar
hmmm
Green is pretty high priority as well....just different.
You don't want any warning lights on your dash lighting up!
Doug
Old 05-30-2013, 10:12 AM
Banned
hmmm
Nope - I think most would consider no/low oil pressure to be a much higher priority than no/low voltage (even if it is due to a broken belt). . .
Old 05-30-2013, 11:04 AM
db_cooper's Avatar
On the older (and even 3.2s) 911s the green oil warning lamp could flash at idle on a hot day. The owner's manual addressed that issue, explaining it was normal. I had a 2.4 that would do it. Changed out a few new oil pressure switches till I found one that was not as sensitive.
Rebuilt the engine at 120k..no wear on the bearings, rocker arms, camshafts etc.
Anyways..the light is green (lower priority warning and you do probably have an oil pressure gauge too) so as not to be confused with the ALT red lamp and the broken belt priority engine cooling problem.
Old 05-30-2013, 11:37 AM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
No,no,no
It's green to symbolize the color of proper oil, Brad Penn......
Baaahaaaa!
eric
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 05-30-2013, 06:15 PM
Undocumented User
McLaren-TAG's Avatar
Originally Posted by ClickClickBoom View Post
No,no,no
Baaahaaaa!
eric
I read the first post and responded, then deleted it since you beat me to the joke by fifteen minutes.
Old 05-30-2013, 06:30 PM
procan's Avatar
I'm a petroleum engineer, and in the oil &gas business:
Oil = green
Water = Blue
Gas = Red
1969 Porsche 912/911E Hotrod - Light Ivory
2003 D2 Audi S8 - Black (DD for the snow!)
1974 Porsche euro 911S Targa - Grey (Sold! Off to the Netherlands!)
Old 05-30-2013, 06:31 PM
Banned
Oil = green
Water = Blue
Gas = Red
Ahhhhhhhhh, the voice of knowledge (as opposed to the traffic light ideas of go-no go).
Old 05-30-2013, 06:47 PM
80-911SC's Avatar
going by the USA marking system ...
water = blue
gas =yellow
and green = sewer ...
so the first word you think of when you think sewer is the same as if the light goes on AWE SH--
Old 05-30-2013, 07:27 PM
Banned
water = blue
gas =yellow
Oh man, that's too funny!
Old 05-30-2013, 07:45 PM
skinnerd's Avatar
Not true.
I smoked a "brand new" 2.7 MFI RS engine because I didn't acknowledge the flashing red "no voltage" light in time.
By the time I pulled over, my engine was smoking and "toast" literally.
Required a full engine rebuild.
Without the fan, your heads and cylinders will get so hot they will distort in shape.
Not a good thing.
Doug
Old 05-30-2013, 08:50 PM
Banned
Originally Posted by skinnerd View Post
Not true.
Not a good thing.
Sir, you are mistaken - the loss of oil pressure, in any internal combustion engine, is a far more serious problem than the loss of cooling, and there is no way you can deny this if you know anything about engine mechanics. For example, you can operate the engine, withough concequence, for much longer periods without proper cooling than you can without oil pressure.
Old 05-30-2013, 09:06 PM
Cajundaddy's Avatar
Simple. Green is the international symbol for all the money you are about to burn up if you ignore the light.
2009 Cayman PDK With a few tweaks
2021 Cayman GTS 4.0L
2021 Macan (dog hauler)
Old 05-30-2013, 09:20 PM
safe's Avatar
Not true.
Not a good thing.
You will probably go slightly further without the fan than oil pressure but you are splitting hairs...
Both lights warrants an immediate shutdown unless its unsafe for your health to stop.
Magnus
Old 05-31-2013, 04:27 AM
LjH LjH is offline
LjH's Avatar
lost the generator belt on a 912. The pulley half split.
Waited for the head temp to drop then made a mad dash home , about 10 miles, shutting the engine down on any decent (down hill).
When I got home popped the engine cover and placed a fan blowing on the engine.. No ill effects. Wouldn't have even tried that with no oil pressure. That being said when you see either light STOP !
Old 05-31-2013, 08:30 AM
Banned
Where did I say that it is OK to keep driving if the low voltage light comes on?
There is no "splitting of hairs" going on in my post(s). I originally responded to the OP when he said/asked, "red = high priority, green=low priority", and told him that this is false because low/no oil pressure is a far more serious problem than low/no cooling (which it is and no way can anyone argue otherwise if they have any knowledge of the workings of an internal combustion engine). Skinnard then chimed in stating that my post was "not true" and I then corrected him, too, as I feel it is important to check misinformation on these forums.
And by the way, one would go MUCH farther without the fan than without oil pressure.
Old 05-31-2013, 08:38 AM
Taking it apart is easy
Jerome74911S's Avatar
Hot head problem.
Jerome
PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com
Old 05-31-2013, 08:53 AM
Banned
Originally Posted by Jerome74911S View Post
Hot head problem.
Nope - I simply think it is important to not let misinformation slide when I read it on here (nice pun, though).
Old 05-31-2013, 09:02 AM
