testa-rossa's Avatar
Holes in Floor?
I'm in the process of replacing my carpets and I noticed that there are 4 holes drilled into the passenger foot well. I noticed it because the sound deadening material is starting to break away. Is this normal?
Old 05-25-2013, 11:00 AM
E Sully's Avatar
No.
Ed
1973.5 T
Old 05-25-2013, 12:10 PM
86 ssinit's Avatar
Not normal. Looked at a 79 sc and it had the same type of holes on the passenger side and 2 or 4 eye loops on the driver side. He said a PO had raced it and they were from a racing harness of some type.
1986 Porsche 911 Targa
1983 911 sc
2015 WRX
Old 05-25-2013, 01:55 PM
AutoBahned
RWebb's Avatar
not a safe harness...
sand off any burrs, prime/paint & stick some dum dum in there before putting down the damener
on the ext., recoat with undercoating over the protruding dum dum
Old 05-25-2013, 03:13 PM
So, what's the best way to fill them in? what is dum dum?
Old 05-30-2013, 05:53 PM
El Duderino
tirwin's Avatar
Dum dum is a putty-like stuff that is used in places like the window corners. It is sorta like plumber's putty -- doesn't dry out and is more sticky.
Old 05-30-2013, 06:49 PM
AutoBahned
RWebb's Avatar
aka strip caulk - 3M makes it - any FLAPS
Old 05-30-2013, 08:05 PM
Home Depot in the electrical section. Used after you drill a hole in a stud and feed wire thru.
Old 05-30-2013, 09:16 PM
