bbdhull's Avatar
Headlamp removal for paint less dent removal
Saw the paint less dent removal guy tonight for an estimate to remove a dent on my front fender,he ask me to remove the Headlamp assembly so that he can reach from there. Anybody got that fix the same way ?
Bruno
88 Granite Green Targa
04 Silver A4 Avant- 13 A3 S-Line
87 Black 944S -Gone
Old 05-28-2013, 05:43 PM
pete3799's Avatar
He's not going to reach that from the headlight bucket.
Pete
79 911SC RoW
Old 05-28-2013, 06:00 PM
Eva
911SauCy's Avatar
Right.
Inner fender no
'78 SC Targa ~Brynhild~ Insta: @911saucy
"The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman-
Old 05-28-2013, 06:02 PM
eh. You'd better remove the right front wheel instead. You might also get a better paintless dent removal guy.
Old 05-28-2013, 06:20 PM
OCPO
Storage Man's Avatar
[QUOTE. You might also get a better paintless dent removal guy.[/QUOTE]
Lol...
2018 X5
86 911 Targa 3.2
80 Mercedes 450SL
2006 530xi BillyBoat/H&R's....gone
Old 05-28-2013, 07:26 PM
Go-Kart Mozart
JAR0023's Avatar
Your PDR guy is thinking conventionally and treating the 911 like a modern car. In his mind he wants to insert a long enough tool to reach the dent have the tool parallel to the top of the fender and the pick end perpendicular to the top of the fender. He'll sight down the top of the fender and use the headlamp bucket for a fulcrum. Problem is that isn't going to work. -J
86 Carrera
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken
Old 05-28-2013, 08:05 PM
Cooper911SC's Avatar
No need to remove headlight.
You will want to raise the front of the car so the wheel will hang down from the suspension. The PDR guy can use the top of the tire for leverage.
He might want to lower the car some for better positioning or use a small block of 2" x 4" for a spacer on the tire.
He will *possibly* have to work around the lines to the fender oil cooler. That dent looks pretty high though.
My guess is he wants the headlight out so he can either drill a hole in the back of the bucket for access and leverage or *possibly* use an existing wiring harness hole for access.
If you talk with the dent guy and have clear communication he shouldn't need to do ANY drilling.
I work with PDR guys on a regular basis while providing detailing and other services for my clients.
Be willing to pay a little bit more or help with access and the results will be better.
If the dent guy is unwilling to work with you find another one!
There is VERY little need to ever drill a hole on a G series 911 for dent access!!
That dent wholesale looks to be a $50- $60ish repair. That's assuming you're a regular client and send business his way.
Retail with the guy coming to you and jacking the car up etc. I would expect $120-$150. Totally reasonable.
Best of luck with getting it straightend out.
Cooper
Old 05-28-2013, 08:06 PM
bbdhull's Avatar
Thanks for you input guys,he quoted me $80.00 for the work.
With all you said and him telling me that the paint might crack since it's 25 years old, I will put this on hold for a while.
Should I wait until it's warmer and let the car in full sun for the paint to be more flexible before someone try to work on it.
Bruno
87 Black 944S -Gone
Old 05-29-2013, 06:10 AM
Project Addicted
Interior of headlight bucket. Yours may be slightly diff depending on year.
Jon
1966 912
1976 911 3.4 Backdate Project
1986 944
Old 05-29-2013, 09:05 AM
bbdhull's Avatar
Jcslocum,is this a picture of your 89 ?
Bruno
87 Black 944S -Gone
Old 05-29-2013, 09:38 AM
Project Addicted
BRuno, No that is just a random webbernets picture. Everyone said no but I'm a visual guy and the old 100 words things works for me....
Good luck with the dent.
Jon
1966 912
1986 944
Old 05-29-2013, 02:18 PM
If it's an original paint car and the dent isn't too sharp at the center I wouldn't worry about the paint cracking.
(can't see your pic. very well viewing from iPhone)
Deep dents and sharp dents have the hugest likely hood of paint cracking because the PDR person has to push hard on a small area.
I wouldn't worry too much.
Cooper
Old 05-29-2013, 03:37 PM
