RE: 1980 SC Caliper Rebuild Advice
I am rebuilding the the front and rear calipers on my 80 SC and noticed the original pistons are pitted which seems like normal wear....should I replace them with stainless pistons and if so, which ones? Any other recommendations for the job?
Thanks |
I'd send them to Eric Shea at PMB and be done with it... Much better than just a rebuild.
JR |
Unless you're rebuilding them for fun, go with PMB. Excellent work over there. They send you a restored set right away, and then refund you the core charge when you ship your old calipers to them.
To quote Eric: "Stainless pistons are available at $39.00 but I feel that, unless you really need them, there is no advantage in getting them. We vibratory polish all of the pistons and re-coat them with a factory grey heat coating." |
2nd & 3rd PMB
2nd & 3rd PMB
Go with Eric at PMB and save yourself a lot of grief and $$ in the long run. He also has the nice brake pads to go with your fresh calipers too. My PMBs & Pads "ROCK" ! :cool: |
A lot of grief? I just rebuilt my front caliper. It cost $5 for the rebuild kit. It took a while to get one of the pistons out (seized), but then I polished them and slapped them together in 30 minutes. Not too bad for $5.
If one is stuck, put a big C clamp on the good one so it wont move a connect the hydraulics to it and have someone gently step on the brakes. Hydraulic pressure will do the hard work. Clean the seal groove really well , bent dentists pick -and only used new fluid to lubricate the seal, a ATE break grease on the piston and backside of the dust cover and your go to go
The safest way I found to remove a stuck piston is with a grease gun and a zert for the bleeders. Hopefully, you don't need it but that was the only way I could safely remove one of mine.
You can clean it up with a little rubbing alcohol, Q-tips and a Handyvac helps to suck the alcohol back through the bleeders. |
| All times are GMT -8. The time now is 02:25 PM. |
