Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 911 Technical Forum
AAEEEEE!
1988 911: do I have a G50 or 915 transmission
From the PP technical section;
The 901 transmission requires a 17mm hex key to remove the M25x1.5 plug. On the 915 transmission, used on 911s from 1972 through 1986, the plug is the same, but located on the bottom of the transmission instead of the side. With the G50 transmission, used on 911s from 1987 on, the locations of the plugs were similar to those on the 915, but the plug type changed from requiring a large hex key to requiring only a 19mm socket.
When I changed my gear oil today I had hex head plugs and drain plug was onthe bottom. Does this mean I have a 915 instead of a G50? Would a previous owner have swapped transmissions (can the be swapped)?
Old 05-30-2013, 06:18 PM
Undocumented User
McLaren-TAG's Avatar
If it's an 88 then you got a G50. More than likely someone changed the plugs during the life of the car. I have an 86 with a 915 Transmission and I've got the 19mm plugs. Maybe I took yours and swapped them with mine. The 19mm plug is easier to work with.
Old 05-30-2013, 06:34 PM
86FlatSix
JQ911's Avatar
Must be a G50. What is your shift pattern? If Reverse is on your LEFT FORWARD beside 1st gear its G50 if its RIGHTMOST BACKWARD beside 4th gear its a 915.
86 911 Coupe (weekend warrior)
09 997.2 C2 (semi-daily)
Old 05-30-2013, 06:43 PM
Immature Member
dentist90's Avatar
If it has a hydraulic clutch it is the G50. The size/style of drain plugs is not an accurate indicator.
1984 Carrera Coupe = love affair
1997 Eagle Talon Tsi = old girlfriend (RIP)
2014 Chrysler 300 AWD Hemi = family car
"Lowering the bar with every post!"
Old 05-30-2013, 06:56 PM
AAEEEEE!
Left forward for reverse - good to know its a G50
Old 05-30-2013, 07:11 PM
paul284pt's Avatar
Hi,
Anyone know where I buy one of these please?
http://forums.pelicanparts.com/uploads22/g501369967994.jpg
Thanks in advance,
Paul
1980-4 924 Turbo with mods. ex Tony Dron (12th at Le Mans 1980 with works 924 Carrera Turbo); 1984-9 911 SC; 1989-93 911 Carrera SE Sport; 2010- 964 Carrera 2 (project); 2012- Cayenne
Old 10-04-2014, 01:57 PM
Probably here or at your dealer
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 10-04-2014, 03:11 PM
paul284pt's Avatar
Nothing here at Pelican, as far as I can find anyway.
I can't find them anywhere, it's an SC shift knob with a G50 pattern
Cheers,
Paul
Old 10-06-2014, 05:04 AM
Paul, a buddy of mine has sent Porsche part numbers here to pelican when he needs the odd part or two, and believe it or not, these folks somehow find the part and get it too him. Pelican does a great job when it comes to oddball parts. And your plug is definitely not oddball, so I am sure they will help.
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 1983 Suzuki GS1100E
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 10-06-2014, 05:30 AM
Cars and Cappuccino
tdw28210's Avatar
Cheers,
Paul
Paul,
Richwood makes nice aftermarket G50 shift knob. All aluminum in a Titanium color. I just ordered one from the UK last week.
http://www.carsandcappuccino.com
1987 Cherryrot G50 Coupe
1985 Prussian Blau M491 Targa - 1 of 65 in the US
1977 Mexico Blue flared, 3.2, back date, sunroof-delete Coupe - in process.
1972 Black T coupe to Longhood Turbo R5 tribute car (someday)
Old 10-06-2014, 07:24 AM
paul284pt's Avatar
Hi Christopher,
Thanks. I can get the SC knob but not with the G50 shift pattern (Carrera 3.2's & 964's). I have ordered an SC knob but I will maybe have to find a G50 pattern button, if I can't find a knob with the correct pattern.
Or:
Thanks for that. I can't seem to find them through Google or Yahoo could you possibly send me a link please?
Cheers,
Paul
Old 10-06-2014, 07:42 AM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
