What is this oil tank hose (72T)
This connector piece seems to be weeping oil, and I cannot find the correct one on pelican. I am starting to wonder if this is a not stock piece and the hose I am looking for goes right to the tank.
I am talking about the one to the left of the oil drain plug.
This is on an oil tank for a 1972 Targa. I am going to be doing an engine swap and want to make sure I have spare hoses to replace the old ones, or the ones that I will have to saw off to get off (hopefully none).
Thanks!
www.akalikoskateboards.com
72 3.0 RSR flared Targa
Old 05-31-2013, 12:32 AM
Send a message via Skype™ to Porboynz
I think its this one although the picture does not look the same length.
911-207-301-02-m100
Its just a piece of hose so if the above part is too long its a simple job to cut to length. The original hose does get hard and leaks once disturbed. Same with the S shaped hose that joins the other end of that pipe to the oil cooler, I recommend you order this as well, its 911-207-318-01. Make sure you use hose clamps that do not damage the rubber
1972 911T Coupe with a '73E MFI engine and 'S' pistons
10 year resto mostly completed, in original Albert Blue.
***If only I didn't know now what I didn't know then***
Old 05-31-2013, 03:13 AM
This should be a 72 only part as it goes to the oil tank in the fender well, that only 72 had. Unless porsche was able to relocate the tank and use the same hoses.
Old 05-31-2013, 08:18 AM
