Temporary downgrade from 3.0 to 2.7, needs parts list
Hi there, my 3.0 in my 82sc needs a rebuild which I plan on doing myself. For the time being I was going to but a 2.7 from a 77 911s (that I have had in the garage) in the car because I want to drive the car while I take my time doing and learning the rebuild on the 3.0. What are some of the things that I will look to change to make it adapt and fit or is it a simple plug and play?
Clutch/plate? Fuel pump (different pressure)? etc... Thank you! |
bump
3 pin cdi, oil line to tank
Pretty simple You'll need the 3 pin CDI as Finty says The fuel lines may be different and you'll need a 2.7 Tach though an autometer will work Oil lines, clutch, are the same
Easy job |
| All times are GMT -8. The time now is 09:09 AM. |
