irl irl is offline
irl's Avatar
Send a message via AIM to irl
Winter is finally gone, dont forget to check for mice- photo
Pulled the car out of the garage for a spring run and it was running hot. Pulled the shroud covers and found this massive nest packed around the oil cooler and last cylinder.
79 SC unmolested
75 911 backdated RSR widebody
71 911T having fun skinny
63 356 outlaw frustrating purists
25 GTS
Old 05-31-2013, 07:30 AM
Topless crazy
seanratpel's Avatar
good catch - too funny!
Old 05-31-2013, 07:39 AM
pete3799's Avatar
I hate meeces to pieces.
Pete
79 911SC RoW
Old 05-31-2013, 08:01 AM
Taking it apart is easy
Jerome74911S's Avatar
Pete, you've got mice? I don't believe it.
BTW My car is on the road, finally.
Jerome
PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com
Old 05-31-2013, 08:57 AM
Senior Member
Jdub's Avatar
This pic will be the go-to whenever any of use refer a user to the issue of carbon-based mice forms. Once again, cannot stress how a cat will clean up all of this. My 3 live to find anything in, near, or around our cars. Treats!
'78 Targa in Minerva Blue
Old 05-31-2013, 11:00 AM
frannyB's Avatar
The next question is just where did all that fluff come from?
Franny
White '86 Carrera Cab "Shamu"
Old 05-31-2013, 11:02 AM
pete3799's Avatar
You need some?
Good to hear you're back on the road.
Pete
79 911SC RoW
Old 05-31-2013, 12:02 PM
ejp ejp is offline
ejp's Avatar
Originally Posted by irl View Post
GROSS! I hope that you used some rubber gloves, or at least washed your hands after handling. The scat in there carries diseases that you really don't want. Glad that you cleared it though - there's a bit of a fire risk associated with rodents (next door neighbor's '68 Vette experienced an electrical fire due to {what turned out to be} rodents gnawing on wiring).
In any case, this post details what I did to deter those little buggers. I found a nest in the p-car's frunk, as well as under the pillon of my motorcycle - I planted the little pepperminty canisters from the linked post stashed all over my motorcycle, around my cars and in the p-car's frunk. I have not experienced any vehicular rodent problems ever since.
Next: Battling the little ants that are crawling all over my grocery hauler.
-Ethan
Old 05-31-2013, 12:43 PM
AutoBahned
RWebb's Avatar
mint oil is rumored to be worthwhile
Old 05-31-2013, 03:16 PM
DanielDudley's Avatar
Where did you find that, and how did you access that exactly ?
Old 05-31-2013, 03:34 PM
kugelfischer's Avatar
and is that a cooked mouse @ 11:00?
1973 Coupe
Projekt X (AKA bunch o' boxes full of parts)
Old 05-31-2013, 03:42 PM
Cooked Rodent
This critter here took down an electrical substation at my work location. His rear legs make it seem like he was auditioning for the Flying Wallendas'. High wire act proved fatal.
96 993 Cab, 73E Targa, 72S Targa
Old 05-31-2013, 03:55 PM
Unobtanium-inc's Avatar
The same thing happened to me last year, running hot and discovered a cozy mouse house on the cooling fins -- except it was my tractor! -- Matt
http://www.unobtanium-inc.com
356 Registry 17369
Early 911S Registry
912 Registry, PCA
Old 05-31-2013, 07:00 PM
irl irl is offline
irl's Avatar
Yes that is a cooked mouse and all that material came from a moving blanket on the other side of the garage. To access it I removed both shroud covers on both sides of the fan and using a flashlight and started reaching in until I found the mass of material. An enormous amount as shown was packed up against the oil cooler on the back right.
Old 05-31-2013, 07:24 PM
Weseeeee911
Nice catch! Good thing you kept an eye on your temp gauge.
Al
80SC 95-present
Old 05-31-2013, 08:19 PM
Thanks. That is a boatload of material there.
Old 06-02-2013, 04:11 AM
non-whiner
mreid's Avatar
Dan, what state are you in? I found similar under the shifter link cover. Only mine was carpet underlayment and it was mixed with grass seed from a bag on the other side of the garage, a shredded blue shop towel, and scat. Rodents really do 5hit where they eat!
"Too much is just enough."
Old 06-02-2013, 07:04 AM
