ganun's Avatar
Trouble filling the gas tank
87 with all the hoses new, no gas smells when topped off etc, BUT, is there a trick to filling the tank? The nozzle will click off if I try to fill the tank any faster than about half speed. Very annoying. I was thinking its the restrictor, so then older (pre 74 ?) cars without the restrictor, can be filled at full nozzle delivery?
George
Old 06-02-2013, 02:01 PM
1983 911SC Chiffon Weiss
mlfox's Avatar
Try turning the fill nozzle 180 degrees as you top off.
Regards,
mlfox
Old 06-02-2013, 02:07 PM
RETIRED
Joe Bob's Avatar
Turn 180 degrees as noted above. Try not to fill it too full, you'll just end up overflowing and/or backing fuel into the vapor recovery system.....
2012 ML350 3.0 Turbo Diesel
Old 06-02-2013, 02:29 PM
pete3799's Avatar
turn 180*
Pete
79 911SC RoW
Old 06-02-2013, 02:47 PM
ganun's Avatar
These cars are just plain weird, full of idiosyncrasies.
Old 06-02-2013, 02:54 PM
Regards,
mlfox
DO NOT TOP IT OFF!
That can screw up the evaporative control system. (That's true of any car, not just Pcar.)
Works fine if you don't push the nozzle all the way in. Pull it out an inch or two when you fill, don't need to turn it upside down. Turning upside-down (180 deg) can defeat the auto shut off. When it clicks, don't put any more in.
The auto shut off is controlled by the little hole in the bottom of the nozzle; if it's on top, it may not work... gasoline everywhere.
Old 06-02-2013, 05:20 PM
86FlatSix
JQ911's Avatar
+1 Pull it an inch or two. This was the start of my many adventures as a new PCar owner. I got it from the Porsche dealership with almost 1/4 gas left. Had to drive it home for a good 70 miles. Drove to the nearest BP station and couldn't figure out why I can't fill up as nozzle stops every 2 secs. Got on my Iphone search thru Pelican and found similar thread so I lifted the nozzle up and got the tank full.
74 BMW 2002 (rust rocket)
86 911 Coupe (weekend warrior)
09 997.2 C2 (semi-daily)
Old 06-02-2013, 06:17 PM
DUK DUK is offline
DUK's Avatar
75 911 Indian Red- RUFWAN2B 2000 Boxster
2000 & 2007 Dobies
www.stahlwerks.com Cages and preparation for your Porsche
“People who never make mistakes must get tired of doing nothing”
Bill : The origin of the orgy of Porsche
Old 06-02-2013, 06:21 PM
Pulling the nozzle out an inch or two does not work on my '81. I have to turn it 180 to be able to fill reasonably smoothly.
"Life is good"
Old 06-02-2013, 06:34 PM
tazzieman's Avatar
Originally Posted by DUK View Post
Stops the hose abrading your paintwork. Another example of Superior Engineering
'81 924 , '85 944 , '78 911SC , '82 928 5.0L
"They run best being run close to the ‘limit’ and done so regularly" - Grady
Old 06-02-2013, 06:35 PM
theiceman's Avatar
turn it 180 auto shut off works just fine.
so many things to learn with this car
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 06-02-2013, 06:39 PM
Fleming's Avatar
Like in DUK's photo above... you point the nozzle the same direction as the inside pipe. And yes it will click/shut off when the fuel gets to the top.... but you should shut it off just before you hear it coming up the spout.
Top off tank, go out on the track at the home track BIR - high speed banked turn one driven at 120 - 145 (what ever your car will do) centrifugal force -fuel leaks out the overfill - lubricates the drivers side rear tire...way too much fun...getting the car to straighten back out. You'll never overfill the tank again.
Old 06-02-2013, 06:43 PM
