Red face not turningover sometimes
I have a '72 targa w/74 2.7 motor that runs off of 2 small batterys. checked the charge it's 12v .If it sits it will turn over and starts up easily ,but if I turn it off and try to start if again I hear a clicking sound and it won't turn over to start and I have to bump start it . I thinkin it's the solenoid ? any other ideas before pull it out.
Old 08-25-2001, 07:07 PM
RETIRED
Joe Bob's Avatar
Unhappy
Yep...solenoid. Sometimes if you hit it with a BFH, it will free up and start.
Old 08-25-2001, 07:12 PM
Early_S_Man's Avatar
If you disassemble starter and clean with brake degreaser spray ... and clean off all of the rust and corrosion, and reassemble with plenty of moly grease, the problem will sometimes disappear!
Dirty, corroded battery terminal and ground straps, trans-to-body ground straps can also cause same problem!
Warren Hall
1973 911S Targa
1992 Dodge Dakota 5.2 4X4 parts hauler
Old 08-25-2001, 07:25 PM
rstoll's Avatar
Post
Yeah Warren, but a BFH is more fun!
Robert Stoll
83 SC
83 944
Old 08-25-2001, 09:32 PM
