-   -   not turningover sometimes (http://forums.pelicanparts.com/porsche-911-technical-forum/7541-not-turningover-sometimes.html)
hannz1 08-25-2001 07:07 PM
I have a '72 targa w/74 2.7 motor that runs off of 2 small batterys. checked the charge it's 12v .If it sits it will turn over and starts up easily ,but if I turn it off and try to start if again I hear a clicking sound and it won't turn over to start and I have to bump start it . I thinkin it's the solenoid ? any other ideas before pull it out.
Joe Bob 08-25-2001 07:12 PM
Yep...solenoid. Sometimes if you hit it with a BFH, it will free up and start.
Early_S_Man 08-25-2001 07:25 PM
If you disassemble starter and clean with brake degreaser spray ... and clean off all of the rust and corrosion, and reassemble with plenty of moly grease, the problem will sometimes disappear!
Dirty, corroded battery terminal and ground straps, trans-to-body ground straps can also cause same problem!
Warren Hall
1973 911S Targa
1992 Dodge Dakota 5.2 4X4 parts hauler
rstoll 08-25-2001 09:32 PM
Yeah Warren, but a BFH is more fun!
Robert Stoll
83 SC
83 944
