-   -   H4 conversion to H1 socket (http://forums.pelicanparts.com/porsche-911-technical-forum/754196-h4-conversion-h1-socket.html)
h.wong 06-04-2013 03:53 PM
Guys,
How would i convert (wire) an existing H4 socket headlamp.. to a H1 light bulb..
for headlamps...?
TIA,
Harry
DRACO A5OG 06-04-2013 04:05 PM
I don't think you can H1 needs the H1 housing to ground off of it. Sell your H1s and get H4s you will probably have money left over as H1s are rare.
h.wong 06-04-2013 04:10 PM
Thanks Jim... but .. H4 socket direct to an H1 bulb...? make any sense..?
DRACO A5OG 06-04-2013 04:24 PM
Can you post a pic or if you want yiu can check out my H1s to see what I did.
Pm me your cell.
Jim
RWebb 06-04-2013 04:54 PM
the wires to the headlights terminate outside of the headlamp assembly, and you can cut those connectors off and use new ones suitable for H-1 headlights
to change from H-4 to H-1 headlights the entire assembly must be replaced - bulb, bowl, and reflectors
if English is not your first language go ahead and post in your native language; there is probably someone here who can translate if not answer you directly
