-   -   What can someone tell me about this engine (1965)?...serial number picture attached (http://forums.pelicanparts.com/porsche-911-technical-forum/754258-what-can-someone-tell-me-about-engine-1965-serial-number-picture-attached.html)
billh1963 06-05-2013 06:06 AM
Supposedly from a '65 (NOTE: car was scrapped years ago...I do not have the car and it was crushed years ago).
Engine was upgraded to 2.2L. Weber carbs. Use as is or is its value such that it should be sold and I should get another engine with more power for less $$?
http://forums.pelicanparts.com/uploa...1370437338.jpg
http://forums.pelicanparts.com/uploa...1370437355.jpg
http://forums.pelicanparts.com/uploa...1370437367.jpg
redstrosekNic 06-05-2013 06:24 AM
You should post the case numbers. I'm sure Grady or someone else with lots of knowledge will respond.
roblav 06-05-2013 06:45 AM
If the engine type number is 901/01 or 901/05, it is probably more valuable to someone else.
billh1963 06-05-2013 06:52 AM
http://forums.pelicanparts.com/uploa...1370440319.jpg
356RS 06-05-2013 08:44 AM
65 serial numbers are from 900361 to 903550 and engine type code should be 901/01 so your #901561 falls right in there.
billh1963 06-05-2013 09:39 AM
Thank you, Mark. What I am struggling with is do I keep this motor (in a 914) or sell it to someone with an early car? I know that with the prices of early cars going out the roof, I won't be able to afford an early car. But, I would hate to think there is an early car needing a correct motor when a newer (less rare and less expensive motor) would suit my needs just fine. Guess I'll have some thinking to do!
