| Registered User Join Date: Feb 2013
				Emergency Brake Retaining Bolt Torque Specs
			Hey Guys,  I am in the process of rebuilding the emergency brakes on my 88 911 Carrera Cab. I am at the point where I am torquing the 4 bolts that hold the emergency brake cover to the control arm and I am in need of the torque specs. Also should I use some type of never seize solvent before torquing down or is this excessive? As always, Thanks for your thoughts. Cheers, CMV | ||
|  06-05-2013, 06:32 PM |
| Tags |
| adjustment , e-brake , emergency brake , pads , rebuild |
