-   -   Concern about ignition coil (http://forums.pelicanparts.com/porsche-911-technical-forum/754420-concern-about-ignition-coil.html)
prebordao 06-06-2013 02:32 AM
Sometime ago, I changed from points to an electronic setup similar to the Pertronix one.
At the time, I didn't thought about the standard coil... is it ok with the electronic ignition ?
theiceman 06-06-2013 03:06 AM
depends.
a cdi ignition requires a different coil spec to a tci ignition system. i just went through all this looking for a spare for my cdi.
lorens sight has some good info on the specs of the coils. just go take a look
prebordao 06-06-2013 04:42 AM
I have CDI, and I didn't change the coil.
T77911S 06-06-2013 05:31 AM
IF you still have the CD unit, use the coil for the CD.
