Koni Strut Concern
I am working on swapping my suspension out for some new equipment and ordered the Red Koni 86 1942's for the fronts... When I put one into the strut housing and tightened the gland nut, I noticed approximately 1-2mm of vertical play (the lower portion of the shock was visibly moving). I checked to see if the gland nut was fully tightened and it was. I used the proper spanner wrench to tighten as well. Should this 1-2mm of vertical play be a concern? I thought it would be fully locked in place but to no avail. Has anyone else had the same experience? TIA
'75 Gulf Blue Carrera #119 |
The gland nut should tighten down on the shock and hold it firmly, usually there is 1 or 2 threads showing when tightened to the specified torque. (Very tight)
Therefore if you have no thread showing and vertical movement something is wrong. Can you compare the new inserts with the old ones?
1972 911T Coupe with a '73E MFI engine and 'S' pistons 10 year resto mostly completed, in original Albert Blue. ***If only I didn't know now what I didn't know then*** |
I would rather be driving
Do you have the right gland nut? The Koni inserts have a different gland nut than Boge. Not sure what you replaced.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
That's why I asked... I figured it should have been tightly snugged down in the housing. The inserts I am replacing are Dr SD) early insert from koni and has a different mounting style and Ps SD) original. The gland nuts came with the shocks. I'll see what I can figure out...
Sent from my Galaxy Nexus using Tapatalk 2
