A lot of people disable the system by pulling the relay, a bad no-no, renders the Freq. valve inop, which creates a lean situation at wot, esp. if control press a little high. Most have been inop for so long, when you get the freq. valve working again, it does feel like 20 hp.
I wanted to apologize to Nickshu and the rest of you guys for bringing up the "no oxygen sensor" issue. It wasn't my intention to go off topic like that. We can save that conversation for another time and place.
Nickshu, after you get everything sorted out would you mind logging some CO data while you are driving? I'm curious to see what kind of numbers you get while cruising and at WOT. It can be tricky keeping the sensor in the tailpipe though - I used painter's tape to keep the wire secured along the side of my car and down through my sunroof (also keeps sensor from hitting pavement if it falls out). Thanks! Craig |
If you mess with it, you can get it to run fairly well with out the relay, but as i said, you have no throttle enrichment after the 35 degree throttle switch.
I'm not sure if I can drive it with my Gunson gastester CO meter in the car. Don't think the hoses are long enough. If I had a dyno it would work...but I don't. I can't find the thread with the dyno data with O2 sensor unplugged vs plugged on a Lambda CIS car. It was in a recent post but the thread was not about CIS, it was about dyno and HP figures and the member mentioned it as an aside....
After reading Peter's post I want to go richen it to 1.0% with the O2 unplugged, then plug it back in. I'll wait for my Sears engine analyzer Ebay special to arrive (thanks Psalt!) and check the dwell swing first. Thx all!! |
you can buy a dwell meter at radio shack, auto zone for 20bucks.
| All times are GMT -8. The time now is 02:59 PM. |
