1979 sc backfires ALOT
and doesnt go over 3000-4000 rpm i took her around the block and she did the same thing as in the idle stance it might be a vac leak etc i just want to know the possible causes and ways to fix it thanks
Old 06-08-2013, 12:17 PM
pete3799's Avatar
Not enough info.....
So it was running great and all of a sudden this happened?
Have you done anything to it recently?
CIS i assume?
Got a pop off valve in the air box? Did it get dislodged?
Pete
79 911SC RoW
Old 06-08-2013, 12:34 PM
kodioneill's Avatar
Pete is most likely correct a loose pop off valve will cause the problem you're having. There could be many other things also.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 06-09-2013, 09:50 AM
T77911S's Avatar
could be:
bad control pressures
bad WUR
no power to the WUR
clogged WUR screen/return
bad thermo time valve(TTV) making it rich
air leak
pop off valve as mentioned
cracked air box if no pop off valve
timing
advance not working
fuel
fuel filter
bad fuel
igntion
plugs, cap, rotor
you are really asking for a lot and giving us very little to do it with.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 06-10-2013, 04:09 AM
