-   -   Removing Lambda brain harness (http://forums.pelicanparts.com/porsche-911-technical-forum/754842-removing-lambda-brain-harness.html)
toddu 06-07-2013 08:29 PM
Have everything out except the wire running through the bulkhead by the pedals into the front fuse block.
How do you remove this wire? I can't find it on the trunk side. And where does it connect on the fuse block?
Can I cut it and wire nut it?
Todd
Nickshu 06-07-2013 09:22 PM
Several of those wires run in a void between the frunk floor and gas tank. Difficult to reach without removing the tank.
Are you ditching CIS for carbs?
boyt911sc 06-07-2013 09:42 PM
Red wire.........
Todd
Todd,
The red wire from the ECU wire harness supplying power to the FV relay goes to S18 (fuse #18).
Tony
toddu 06-08-2013 04:30 AM
Yes, I'm moving to carbs.
Fuse 18, thanks!! I'll see if I can remove it there and go the other direction.
Not going to remove the tank. Did that to install sway bar and don't feel like doing it again just to remove 1 wire.
Todd
toddu 06-08-2013 08:51 AM
Succes!!!
No please tell me my fuel pump is still going to operate :-)
Not understanding the tie into the FP relay.
Todd
