plugs for 83 SC euro
Could anyone tell me which are the proper plugs for an 83 SC euro motor. Plug gap?
John Brasfield 91 C2 78 SC For sale 76 3.6 68 Datsun 2000 Mr. Magoo, 02 330ci |
According to the German NGK site the Euro 83 SC takes a B9EVX @ 0,8 gap.
http://www.ngkntk.de/pages/gb/ngk/index.html to compare I looked at the US site to see if they were the same and.. The US NGK site shows BP7ES @ .028 gap. (For a US car) Perhaps someone can verify the results from the German site. Last edited by RickM; 02-07-2003 at 07:13 AM.. |
I use the BP7ES plugs in my 2.7 with that same gap. I believe these are also correct for the SC.
Mike
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
The BP7ES seem to be for a US Spec SC.
The B9EVX appears to be for a Euro (at least German) SC. I have an Email into NGK. Hopefully they'll verify.
Warren & Ron, may you rest in Peace. |
I use Bosch W3CC in mine, although people say the NGK's are better.
Cheers,
1984 Carrera - 3.6 Conversion, 326bhp, 1020kg - SOLD 1987 930 - SOLD 1983 911 SC Targa - SOLD http://forums.pelicanparts.com/impactbumpers.com - Classic 911's and nothing else |
My engine is a "Euro" also, and the BP7ES plugs work great. I think they work fine in the SCs, too.
Mike
Mike the 2.7 and 3.0 are two totally different engines. I'd feel more comfortable "knowing" they work great instead of "thinking" they work great.
They're not that different, really, in the big scheme of things. Suit yourself, though. It's your engine.
Small clarification - NGK recommends a BP7ES for a US 3.0 SC engine (1983) - I don't think the *Euro* engine was that different....
IROC, What are the differences? I'm curious.
If your asking me to quantitatively list all the differences between a 1983 Euro SC engine and it's US counterpart - there are lots of resources out there that I'm sure you can consult. I think the point, though, is that *from the standpoint of which NGK plug you use in them* the differences are probably not too terribly relevant. If you have some evidence that a BP7ES plug is harmful for use in a 1983 Euro SC engine, then let me know.
Mike
That's what I figured your answer would be.
Don't use the 7 plug in the '83 Euro motor. It has 9.8:1 compression and should use a colder plug than the US motor. NGK's get colder as the number increases, so use the B9 plug. Otherwise you'll be asking for detonation.
Rob 1980SC euro |
John,
This just in from NGK Europe... Dear Rick, Thank you for your interest in our products. You are absolutely right, the recommendation for the Porsche 911 SC modelyear 1983 is the NGK platinum type B9EVX, gap 0.8 mm. kind regards NGK Spark Plug Europe Andreas Götz
My 83 SC ROW had detonation problems. Putting in the B9EVX plugs was the solution. Thank you!!!
Speed Dog's Chauffeur
Thanks for getting the NGK number
Reiver
John, a guy I know put NGK BPR8ES in my 930-10, cool enough obviously as my car is running cool in 110 degree heat. I range cooler rather than the 2.
That same guy told me that lots of the Bosch plugs for older P cars are made in Brazil with crappy quality just like the fine (expletive deleted) Brazilian coils..... |
I have found that the Euro SC's run best with the BPR8ES plugs in my region. We also have 93 octane fuel here too. I have been known to run 100 octane in mine.
Howard
Howard Freeman 80 911 SC & 74 914 1.8 79 930 & 83 SC coupe,03 996 TT,02 996 C4 03 X/5 3.0. 370,186 miles now Sons daily driver 10 X5 3.0I 224,515 miles |
Reiver
Non-Projected tip?
Did you have to re-tune for the non-projected B9EVX plugs? I had 2 different 9.8 motors that did not plug & play with the W3CC & WR4CC(MFI) non-projected Bosch plugs. Idle RPM dropped & misfires. The tip change altered the flame travel or something in the motor and mine was not happy.
