Functionista
manbridge 74's Avatar
So I have a longgg private driveway..... 128mph @ 7800ft. in OE 74 base model?
Sort of caught me by surprise. Anyone think the PO changed a few items?
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 06-06-2013, 01:49 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Aside from speedo error, if the car is running well, it's probably realistic for a stock 74.
Midyear 911's are in the 90+ mph range for the 1/4 mile. Assuming 10% speedo error, that gives you another mile to increase 25 mph to 115. If the mileage you state is genuine, then you got a rocket, me thinks.
Had my 81 at 135 on the Ohio turnpike going east between 77 and Rt 8 - slight downhill. Was bragging up a storm until I used a GPS next go-around. 123mph - same stretch of road.
Would be interesting to know how much road is needed to get these cars to genuine top speed. Our cars would be in the 130-140 range, I believe, but something has to give - meaning time - to get that last 20mph out of them
1981 911SC Targa
Old 06-06-2013, 02:20 PM
Evan Fullerton's Avatar
My '75 at the time put down 167whp and would do an indicated 150mph + (~where 165 would be if the speedo digits went there) on taller then stock tires.
The skinny fenders make them slippery.
Old 06-06-2013, 03:05 PM
AutoBahned
RWebb's Avatar
you realize BoxsterS can go 160 mph, right?
Old 06-06-2013, 03:35 PM
Taking it apart is easy
Jerome74911S's Avatar
Maybe, but then they don't have skinny fenders, or skinny motors, or skinny drivers.
Jerome
PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com
Old 06-06-2013, 04:52 PM
grateful user
don gilbert's Avatar
Evan, you need to put the GPS on the 75. Only way it can get to 150 on its own with a stock 2.7 is off a cliff. Sorry, its just true.
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do.
Old 06-06-2013, 07:04 PM
That sounds like a fine driveway, not just long!
Dave
1969 911T Coupe
1972 911E Targa
Old 06-06-2013, 07:16 PM
Originally Posted by don gilbert View Post
evan, you need to put the gps on the 75. Only way it can get to 150 on its own with a stock 2.7 is off a cliff. Sorry, its just true.
Classic.
Old 06-06-2013, 08:28 PM
Believe what you will but an honest 150mph is only a little over 6000rpm in 5th on an 8-31 R&P car. 7000RPM in 4th is 140mph.
http://www.californiamotorsports.net/75-79%20915%205%20speed%20stock%20gears.pdf
Old 06-06-2013, 09:57 PM
grateful user
According to your graph, why dont you just throw some s cams in, then you can go 170. Nice if it was true. Might do 120-125 on a good day, with a tail wind, on a slight down hill grade. I know, had one. Think about it, 165 hp, 150 mph? Takes a little more than that. Study up on E=mc squared.
Old 06-06-2013, 10:08 PM
IROC's Avatar
Top speed is not gearing limited in this case - it's drag limited. A stock 2.7 will not reach 150 mph (not enough hp to overcome the rolling friction/aerodynamic drag). I'd guess closer to 135-140 mph on a good day. I did some calculations years ago and it seems that (from memory) you would need 230 hp or so to reach 150 mph.
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 06-07-2013, 04:27 AM
Banned
Speedometer is stock, does that count?
Old 06-07-2013, 07:04 AM
Banned
Send a message via AIM to prebordao Send a message via Yahoo to prebordao Send a message via Skype™ to prebordao
I think that for a stock S in 74 the factory quoted 140mph.
Can anyone attest to that ?
Old 06-07-2013, 08:06 AM
Banned
I showed 135 in my stock 2.7. It was slightly downhill and red lined.
Old 06-07-2013, 11:48 AM
Porsche fanatic
jager911's Avatar
I maxed out at 144mph, 6000rpm in 5th, stock 915, but with slightly tweaked 3.2L, verified with GPS and 915 gear chart. My front end gets light at that speed and I need to add a splitter.
Tire size also affects effective gearing/speed.
'56 Speedster Guards Red
'74 911 IROC- 3.2L, 22/28 tbars, 22 sways, Bilsteins, Big Reds, Seineshift, headers/M&K, slicks, 17" Fuchs, SW
'95 993 -H&R coilovers, turbo sways, GT2 wing, Fabspeed
'74 911 Targa, 87 944T, '75 911 Anniversary Edition-sold
Old 06-07-2013, 01:06 PM
Banned
Gimme some of what you're smoking!
Old 06-07-2013, 01:08 PM
Checked out
McLovin's Avatar
Only if it's a Targa.
Old 06-07-2013, 01:39 PM
Bob Kontak's Avatar
Evan,
Even though you are getting some push back, realize things could be worse. :-)
Hint: "It puts the lotion in the basket"
1981 911SC Targa
Old 06-07-2013, 01:59 PM
No need to smoke anything. Porsche rated the 1973 RS at 152mph. If we use 15% drive line loss, a '73 RS makes 178.5whp. My car with a fairly stock 3.0L made 167whp. Smaller rear fenders, smaller side view mirrors, below euro ride height etc. (my car is not very original in any respect) make up the difference. 150ish mph is an entirely believable speed out of a very nearly stock early 911 so back to the OP's original question. 128mph at altitude is a believable number.
Old 06-07-2013, 02:07 PM
Reiver
Reiver's Avatar
learn to read your tac....put your gearing, rear end, tire size in and get speeds....I never use my speedo as it is off by about 6mph, but that varies at certain speeds....common in P cars for some reason.
Gear Ratio Speed Calculator
Old 06-07-2013, 02:08 PM
