Clutch recommendation
What clutch do you recommend for a 911 with a stock 3.2 and a 915.
Apparently it has now a Sachs KF200-01
Old 06-10-2013, 12:42 PM
fred cook's Avatar
Clutch
I have the Sachs clutch with the aluminum pressure plate. The release pressure is not excessive, engagement is excellent and it uses the spring center disc instead of the rubber center disc. Not cheap, but worth it.
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 06-10-2013, 01:14 PM
emac's Avatar
Sachs , nuf said
Ernie 81sc
Old 06-10-2013, 01:32 PM
Uncertifiable!!!
Uwon's Avatar
I have a 3.2/915 which has been converted to a 3.4 Turbo still with the 915 trani. I had intermitent clutch issues until I went with the clutch offered by Kennedy Engineered Products. Holds nicely up the back straight at the track. If I remeber correctly, they modify Sachs clutches to their specs. Competitive pricing too as I recall.
🇨🇦 The True North Strong and Free 🇨🇦
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, 2024 WRX GT, 911 hot rods on Pelican….
Evolution of a Carrera RST, and Sweet Transplant
Old 06-11-2013, 04:32 AM
