Alternator rebuilder
I am looking for someone who can rebuild an alternator for a 1988 911, in North Carolina or Virginia.
I have a Bosch re-manufactured one from Advance Auto and would like to have it rebuild. |
Send it to AutoLectrics in Campbell, CA
Starters , Alternators, generators, repair, replace, build Many years of great service with this company. They do it right, first time. |
Send to stellar generator in Pittsburgh. Call mark 412-563-2100. Tell him Gary sent you
Thanks, I found one local and will let him have a look at it.
alt
make sure they use the pressed in diodes as the original as i was told that they handle the heat better than the external ones.
Got it back in and the light is still flickering on at idle. Voltage is 12.5 car off, and 14.3 at idle with the light flickering.
I checked the blue wire going to the gauge and everything looked good. The light flickering at idle will drive me nuts. |
measuring
where are you measuring the voltage? should be at the battery.
if that is 14.3 at idle, what is it at 2000? if you are measuring 14.3 at the battery at idle you light should not be flickering. |
I'm measuring at the battery, and yes the 14.3v is at idle.
I went to Advance Auto and let them check the battery and the charging system with their fancy machine. Light is still flickering at idle. This was after a 20 minute drive Battery results voltage 12.85v Measured 1043 CCA Rated 800 CCA Charging system test no load 14.01v loaded 13.68v |
Glen Burnie Generator and Carburetor Shop in Maryland. They just rebuilt my Marchel 55 amp for $70. Looked like new. They have 35 years of service. tele 410 761 0056.
Turn around time was 2 days. Scott |
| All times are GMT -8. The time now is 11:08 AM. |
