wannabee wannabee
glass bumper protection from debris
Area around wheel well getting bad due to wheel debris. Anything special I could spray on there to minimize the deteriorating effect? Thanks in advance.
99 C4 - (let's try this once more) 07 Cayman S - sold 11/17 (not the same) 84 Carrera - sold 3/16 (geez what have I done!) |
Been here a while
I guess you want the flat-black look.
you could put some clear-bra material on the fiberglass, it would gloss it up a bit, I expect. also, I've seen some new spray-on clear bra kits, 3m, even armor all has them......or plasti-dip clear or black might offer more of a debris-resistant coating
looking for 1972 911t motor XR584, S/N 6121622 |
You can get matte finish clear bra film if you want the flat look. If you track the car I would apply 2 layers of the standard ~ 8mil. film and plan to replace fairly frequently.
You can also use a sprayable undercoating such as Wurth SKS. Just mask at the body/wheel edge line for a clean look. This would be more durable and is paintable. Same way Porsche did them originally. Cooper Last edited by Cooper911SC; 06-17-2013 at 06:11 AM.. |
If you like the matt black, go with plastidip for both the look and a bit better protection compared to thinner paint.
73 RSR replica (soon for sale) SOLD - 928 5 speed with phone dials and Pasha seats SOLD - 914 wide body hot rod My 73RSR build http://forums.pelicanparts.com/porsche-911-technical-forum/893954-saving-73-crusher-again.html |
wannabee wannabee
Thanks for the suggestions!!! I'll probably go with plastidip.
