-   -   Should I replace stock clutch with aftermarket or stock? (http://forums.pelicanparts.com/porsche-911-technical-forum/755779-should-i-replace-stock-clutch-aftermarket-stock.html)
spsfiend 06-13-2013 01:42 PM
Hey fellow pelicanites, I configured a few searches but did not find an answer / the advice I am looking for so I have decided to post.
I have to replace the clutch on my 1987 911. The engine is basically a stock 3.2. I do have long term plans to do a 3.6 but its probably at least a couple years away.
I am considering the KEP clutch and a lightened fly wheel from Patrick Motorsports but have reservations of engine stalling with the flywheel even after having a custom chip programmed.
Also, I don't know if its really of value to deviate from the stock clutch if I have no near term plans of pushing any additional HP.
Great appreciate any advice folks can provide as I need to decide in order to order parts and get my baby back on the road!
Best regards,
Gerry
ruwoodbury 06-13-2013 06:56 PM
Gerry,
I have the Patrick MS lightweight flywheel and pressure plate on my '89 and have no problems stalling the engine. Other than a stiffer clutch pedal I don't find any difficulties with start up. It's a little noisier than stock but I really like the way the engine spins up with the reduced mass.
Go for it!
spsfiend 06-16-2013 11:55 PM
Thanks for the input! Can anyone else share their experience with the KEP and Patrick motors ports lightened flywheel set up?
