Ruby911
ruby911's Avatar
Check TRE - they have several options.
tremotorsports.com
- Farrell
1984 Carrera - SW Chip, Factory Short Shift Kit, Cat Bypass - SOLD
1968 Ossi Blue 912 Sunroof Coupe - SOLD
1971 911E - 2.7 Twin Plugged, PMOs - SOLD
1965 356C Outlaw
RGruppe #577
Old 06-14-2013, 05:22 AM
You may want to consider building your own, that's what I did, along with an RS style rear seat delete. I don't have a tubing bender, so what I did was mock up the rollbar using conduit, then took that to one of the NHRA cage builders here and had them bend the same shapes using 1-3/4 DOM tubing. Brought it all back and tack welded it, tested it for fit and then MIG and TIG welded it. If you don't weld the NHRA shops will weld it for you also.
I bolted mine in 4 places, using 3 bolts in each front mount, and 2 bolts in each rear mount. Both front and rear I used the seat belt bolts plus additional bolts.
Then I had the whole thing powder coated.
Chuck.H
'89 TurboLookTarga, 358k miles
Old 06-14-2013, 05:26 AM
ChuckH, that looks amazing.
Have you documented your build an the forum? I'd love to see more pics.
Ayles
Old 06-14-2013, 09:17 AM
tquaglino's Avatar
You said Hot Rod.
I purchased my street roll bar from autopower industries. Before installation I sent it out and had it chrome plated. Its a hot rod detail that brings more attention to the pipes.
For me it was also a way to continue with a theme. All black with subtle touches of chrome.
Old 06-14-2013, 09:54 AM
Ayles
Thanks! No, I didn't document the build and I need to get more pictures. Basically I removed the rear seats and bolted 6x9 'wedge' speaker enclosures to the seat areas; this allowed a rear shelf to sit level from the top of the speaker boxes to the flat area where the seats met the firewall. You can just barely see the front lip of the shelf between the seats.
Covered it all with RS carpeting, cutting out holes where the rollbar connects to the rear seat belt bolts.
Chuck.H
Old 06-14-2013, 12:23 PM
air+fuel+spark
combatic's Avatar
Per your request for a period roll-bar for a 73, talk to Dave at TRE. They can build to suit very reasonably.
Here is my 'Club Sport 2' from them. The hoop replicates the 'ST' hoop shape common in the late 60's, early 70's. I wanted the horizontal bar for my harnesses...had to opt for some safety over looks on this one.
bryan
1969 911T , '04 S2000, '96 900SS, 4x4 urban assault vehicle
R Gruppe #653
Old 06-14-2013, 12:41 PM
tre ... got mine for the rsr
Old 06-15-2013, 09:40 AM
jm993rs's Avatar
I search the same roll cage for a earlyer '68 !!
Please anybody Can imput here the URL for buying this roll cage ??
Think you !
Old 06-15-2013, 10:24 AM
