Roll bar options?
Looking for a period roll bar for a 73 hotrod.
Any suggestions? Would prefer a bolt in. |
Ruby911
Check TRE - they have several options.
tremotorsports.com - Farrell
1984 Carrera - SW Chip, Factory Short Shift Kit, Cat Bypass - SOLD 1968 Ossi Blue 912 Sunroof Coupe - SOLD 1971 911E - 2.7 Twin Plugged, PMOs - SOLD 1965 356C Outlaw RGruppe #577 |
You may want to consider building your own, that's what I did, along with an RS style rear seat delete. I don't have a tubing bender, so what I did was mock up the rollbar using conduit, then took that to one of the NHRA cage builders here and had them bend the same shapes using 1-3/4 DOM tubing. Brought it all back and tack welded it, tested it for fit and then MIG and TIG welded it. If you don't weld the NHRA shops will weld it for you also.
I bolted mine in 4 places, using 3 bolts in each front mount, and 2 bolts in each rear mount. Both front and rear I used the seat belt bolts plus additional bolts. Then I had the whole thing powder coated. ![]() Chuck.H '89 TurboLookTarga, 358k miles |
ChuckH, that looks amazing.
Have you documented your build an the forum? I'd love to see more pics. Ayles |
You said Hot Rod.
I purchased my street roll bar from autopower industries. Before installation I sent it out and had it chrome plated. Its a hot rod detail that brings more attention to the pipes.
For me it was also a way to continue with a theme. All black with subtle touches of chrome. ![]()
Covered it all with RS carpeting, cutting out holes where the rollbar connects to the rear seat belt bolts. Chuck.H 89 TurboLookTarga, 358k miles |
air+fuel+spark
Per your request for a period roll-bar for a 73, talk to Dave at TRE. They can build to suit very reasonably.
Here is my 'Club Sport 2' from them. The hoop replicates the 'ST' hoop shape common in the late 60's, early 70's. I wanted the horizontal bar for my harnesses...had to opt for some safety over looks on this one. ![]()
bryan 1969 911T , '04 S2000, '96 900SS, 4x4 urban assault vehicle R Gruppe #653 |
very nice guys! thanks for the info
tre ... got mine for the rsr
I search the same roll cage for a earlyer '68 !!
Please anybody Can imput here the URL for buying this roll cage ?? Think you ! |
