Megasquirt 2 adding EDIS
I have MS2 running fuel now and am adding ignition with EDIS while my heads are out getting new valve guides and adding a bit hotter cam.
I have all the wiring figured out and done. I have the Goingsuperfast trigger wheel, sensor holder and distributor hole cover installed and have the required 60 degree or 6 tooth offset set up for the sensor.
The question I have is setting the exact trigger angle. I expect to be a degree or two out from 60 and I get that I can put EDIS in limp mode where it stays at 10BTDC and check with a timing light. What I don't get is can I adjust to the exact 10 in TunerStudio or do I need to fiddle with the mount to get it exactly right?
Any BTDT experience?
Kinsley
1980 SC Targa - MS2, EDIS
Old 06-16-2013, 10:03 AM
don't know what btdt is
I have the same components and configuration and just recently did what you are asking about. You can adjust in TunerStudio easily, in the Tools/Trigger Wizard.
I set idle advance to 10 degress, and then adust until the marks align, with a strobe. Actually my goingsuperfast wheel does not have a 10 degree mark and I believe I used the TDC mark. Set idle advance to 0 degrees and check they line up with strobo.
80SC (ex California)
Old 06-16-2013, 01:22 PM
Trond,
Thank you (BTDT is been there, done that)
Kinsley
Old 06-16-2013, 02:49 PM
