Swb rear crossmember the bit w/ turrets
Rust claims another piece of bodywork on my 68S.
Can I backdate a lwb crossmember for swb car? Better to replace with section from a dry state donor? Or refabricate the strut turrets? Thanks Rich |
Buy a solid crossbar mount and replace the rubber inserts. I went with Wevo and I am very happy. You send them the crossmember and they for the new mounts in.
Pete I think he means the shock mount.
For a 68S, yes, replace with donor section. For the LWB cars the mounts are different and they change after 1972 as well, the turrets get larger. How is your torsion tube? |
Have replaced tube and repaired chasis with longitudinal repair panels.
Old tube was mostly held in with sealer, rust and a square iron section welded to the rear kick panel that connects seat pressings to the floor. Yikes. |
| All times are GMT -8. The time now is 11:24 AM. |
