Patronus's Avatar
Post Should my fuel tank be like this?
I have a '68 911 (ex 912) with 62 litre fuel tank (according to its original owners' manual). When my car has about 1/4 left, I can't even consider going around a bend, or the engine will cut out. The fuel splashes around considerably in the tank, to such an extent that I am forced to refill after 45 litres, every time. Is this normal? I mean, shouldn't it have baffles or something inside the tank to keep this from happening?
Martin
Old 08-24-2001, 12:12 PM
Senior Member
Zendalar's Avatar
Post
I have a -71 and it splashes also. My engine won't cut out but I can see the fuel level warning light occasionally when cornering hard.
Old 08-25-2001, 04:12 AM
Patronus's Avatar
Unhappy
I find it strange, since Porsches are meant to be cornered hard. Nobody else with the problem?
Old 08-25-2001, 03:15 PM
Senior Member
Post
Hello
Normally if your red light flashes up in curves or while accel you have some 5 L reserve. If the light is red on the straight the engine will stall in hard curves.
I would check if the tank has to much dirt cloging up the filter mesh.
Grüsse
Old 08-26-2001, 09:44 PM
