Anything wrong with using spacers with my 6s and 7s?
I don't spend any time on the track or autocross. Car s purely for street so is there anything wrong with using spacers? How do 6 and 7 with spacers fill out the wheel wells?
I've got 1" (25mm) spacers on the rear only, fills out the flares nicely.
http://forums.pelicanparts.com/uploa...1371923065.jpg |
Nice!
No problem.
I have 21mm adapters on rear of my 88 with 7's. Correct me if I am wrong but I believe spacers only have holes and adapters have holes and studs saving one from having to install longer studs in the hubs. Anyway, the 21mm adapters fill out the wheel well nicely with no fender interference at all. My son has 18mm adapters on his 85 with 7's. All this at the rear.
Same here. Using 1.25" H&R hubcentric rear adapters--look great and pulled the wheels out even with the fender edge.
Dave http://forums.pelicanparts.com/uploa...1371932363.jpg http://forums.pelicanparts.com/uploa...1371932391.jpg |
I have several sets of spacers if you need. pm me.
Where does one purchase a 25mm spacer?
I thought there was a "rule of thumb" that spacers of more that 10mm shouldn't be used as the wider spacer will put too much stress on suspension components.
Just my $0.02. Separately, to Cattler, how do you like those Michelin Sport A/S tires? |
i used 23mm adapters on my rear 7" fuchs and was quite happy with the results.
before http://i15.photobucket.com/albums/a3.../wheels001.jpg after http://i15.photobucket.com/albums/a3.../wheels003.jpg before http://i15.photobucket.com/albums/a3.../wheels002.jpg after http://i15.photobucket.com/albums/a3.../wheels004.jpg |
What about longer studs? Seems like a 25mm spacer would require some more threads to grab.
I'd like to put a set on the front but have been reluctant to do so because of potential for wheel rub issues. For now it's "on the list". Would love to hear what others have done to the front on an SC and if it was necessary to roll the fenders. |
I used a 1' hubcentric spacer on my 88, and it made all the difference in the appearance. I needed longer studs which I was able to just get on without taking any major components apart.
I put .25 inch spacers on the front (6.35 mm), and 1 inch adapters (25.4 mm) with their own lugs on the rear. I've been running them for a couple years with no issues.
I haven't had any suspension issues at all. |
[QUOTE=Richard C2S;7511590]I thought there was a "rule of thumb" that spacers of more that 10mm shouldn't be used as the wider spacer will put too much stress on suspension components.
Just my $0.02.QUOTE] And then there is the question: Do the spacers improve road handling or are they just improving the looks? |
In my case, it was just for looks. Some day I may get wider rear wheels to get the look w/o spacers. But for now the spacers do the job. |
There are spacers that provide substantial width increases, and most are adapters that attach onto the existing lug nuts and provide their own lug studs in their spacer-adapter - sort of like a mini-hub. I think they begin at around 21mm.
Other spacers are thinner, on the order of 4 or 7mm wide. Be aware that merely slipping these (or a combination thereof) over the stock lug studs (between hub and wheel) will reduce the thread contact with the lug nuts and thus pose a potential safety issue. Sherwood |
| All times are GMT -8. The time now is 11:16 PM. |
