-   -   Know where I can get a 911 CAD (AutoCad) drawing file? (http://forums.pelicanparts.com/porsche-911-technical-forum/75787-know-where-i-can-get-911-cad-autocad-drawing-file.html)
TedSlick 07-27-2002 10:07 AM
Seems lots of you guys are involved in engineering, so I thought maybe someone here could help me out with this.
I need plan and elevation views of a 911 (80's model preferably) in AutoCad (.DWG) or Microstation (.DGN) format. WindowsMetafile (.WMF) might also work.
Thanks...will be very useful in some garage and site planning I'm doing.
andyu911 07-27-2002 10:47 AM
I have 993 front, rear and plan view. Proportion is close not perfect. Interested?
Andy
'87 Carrera
TedSlick 07-28-2002 09:32 AM
^up
wheeee...this request slipped away fast
Andy, yes I'd like to try those files SmileWavy
Anyone have drawings of the 80's style 911?:confused:
brianhinfl 07-29-2002 01:18 PM
I've got a 3-D SC.
stray15 07-29-2002 01:31 PM
I would also love to have those files. I have a 924 drawing. It isn't real good though.
Email is swtncdly@aol.com
Thanks!
TimT 07-29-2002 02:01 PM
You can get really good drawings of the 911 from the factory repair manuals. Volume 2 has the body work section for the 911, along with drawings of all the critical dimensions. If you have access to these manuals make some copies. I have Vol 1 which is the engine and drivetrain. Lots of clubs or groups of friends pool money and buy the manuals, but usually only Vol 1, befriend a mechanic that has the full set and ask to make copies of the drawings.
You could then do the wire frames on autocad or microstation, then all you would have to do is put a surface on the wireframe
I was going to make a wireframe dwg of the 911 then run it through some FEA software to run torsion, impact and other load tests on the 911 so I could learn where to remove material to make my car as light as possible, and where to reinforce fo drive safety
TedSlick 07-29-2002 07:15 PM
TimT, that was going to be my next move (find dimensioned drawings and draft it myself). Ended up locating a .3DS file and converting to AutoCad.
I can now view/plot/render this 3D model '82 911 from any angle:
http://forums.pelicanparts.com/uploads/82 911-1.jpg
http://forums.pelicanparts.com/uploads/82 911-2.jpg
Also found the 993 (2D only):
http://forums.pelicanparts.com/uploa...CH-S-Model.jpg
...and this '55:
http://forums.pelicanparts.com/uploa...sche-Model.jpg
Lots of stuff available...
tbitz 07-29-2002 07:29 PM
Wow!
Can I get the above files too (911, 993 and 550)?
tbitz@yahoo.com
Thanks,
TedSlick 07-29-2002 07:53 PM
YGM :)
les-paul man 07-29-2002 08:19 PM
I would be interested in all the 3D files from above..
seres@attbi.com
thanks.
Wayne 962 07-29-2002 08:56 PM
Hey Ted, can you email a copy to me to? I've got ACAD 13&14 left over from the ole engineering days...
-Wayne
Actually, I can probably find a spot for them on the server...
-Wayne
TedSlick 07-29-2002 09:08 PM
sure, Wayne...
Lemme back-grade them (to Acad 13 or so) and I'll send them along. Then you'll be able to access them with older versions.
Hmmm...just realized I don't know where to send you email with attachments. Will try wayne@pelicanparts.com
andyu911 07-29-2002 10:20 PM
That would be great if we can put them together here. I always have the same 993 on most of my drawings. Also like to have more varieties Porsche.
Andy
'87 Carrera
Wayne 962 07-29-2002 11:30 PM
Okay, download them here:
http://www.pelicanparts.com/temp/Porsche-ACADVer13.zip
-Wayne
Jack K 07-30-2002 12:54 AM
Ted
I would appreciate the files - I use AutoCad 2000
jkampel@bigpond.net.au
Tx
TedSlick 07-30-2002 01:12 AM
Jack, look one post up from yours'. Wayne posted a link to the files.
You can really goof around with them:
http://forums.pelicanparts.com/uploads/rendered911.jpg
...and the accuracy is amazing:
http://forums.pelicanparts.com/uploads/Lego911.jpg
:eek: :eek:
Jadams1 07-30-2002 05:26 AM
Can I get a copy of the 911 CAD drawing please?
john.adams@clariant.com
Thanks!
tbitz 07-30-2002 08:50 AM
You can download a free dxf/dwg view here:
http://usa.autodesk.com/adsk/index/0,,837403-123112,00.html
This viewer allows you to rotate the images to view them from any angle.
niks345 03-01-2012 12:43 AM
Please send me the 3d blueprint of porsche 911 at scpatil.345@gmail.com
Thanx...
