Retired, finally
SiberianDVM's Avatar
fuel hoses in front trunk
I have a 84 Carrera Targa. I'm pretty sure all of the fuel hoses are original and need replacing. The only time I smell gasoline is when the tank is FULL and I take some corners.
Are the fuel hoses in the front trunk best replaced with OEM parts or will bulk fuel hose work?
2009 Porsche Cayenne Turbo S; 2019 Corvette Grand Sport Coupe; 1998 Porsche Boxster; 1989 Toyota Supra ChumpCar; 1989 Alfa Romeo Spider; 1977 Porsche 911S Targa 3.2L"Bwunhilde II" chimera; 1970 Datsun 240Z 2.9L "dogZilla" project
Old 06-24-2013, 06:34 AM
Recreational Mechanic
Nickshu's Avatar
Bulk fuel hose is OK for the short fuel pump to tank hose.
The tank vent hoses (small hoses visible in the frunk) are OK to use as bulk but they are metric so easiest to buy by the foot from Pelican.
The filler tube flex hose near the brake master cylinder needs to be OEM.
The fuel lines from the tank (return) and the fuel pump (pressure) that go from the front, thru the tunnel to the rear of the car are OEM (of course).
Probably a good time to remove the tank filter and clean out the fuel tank as well.
If you are just going for gas smell the most likely source are the vent hoses in the frunk
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches
PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing
Old 06-24-2013, 06:50 AM
Retired, finally
Thanks!
I'll start with the easy ones.
Is there a written procedure for removing the tank filter and cleaning the fuel tank?
Old 06-24-2013, 08:00 AM
I'd check for a leak in the tank first....try the seam on the left front closest to the battery...the coating will hide/mask the fuel leak, but if you're smelling gas all you need is a couple of drops under the bonnet...not to mention the "boom" factor...
1984 Carrera Targa
Old 06-24-2013, 02:31 PM
look for wetness in the vent hoses (ones in the top of the tank inside the trunk). If none, then try changing the fuel sender gasket.
Old 06-24-2013, 02:36 PM
hydrocrust's Avatar
I had fuel smell on new-to-me 82SC. Turned out PO had epoxied broken fuel expansion chamber, and it leaked. Replaced that, did not clear smell, found all three hoses to expansion chamber had small longitudinal splits, replaced the old black hoses with translucent, yellow fuel resistant hoses from McMaster. They will show future splits. Smell gone.
Old 06-24-2013, 06:11 PM
Retired, finally
Thanks, guys. I looked at all of the front truck hoses last night. The "big one" between the filler neck and the tank is smooth rubber, all the others are braided. The filler neck/tank hose looks great so I just tightened the clamps. The other braided hoses look OK but feel soft so I will probably try to replace them.
Do you have to remove the fuse panel in order to replace the small hose that comes out of the bottom of the white expansion chamber and runs through the fender to the black expansion chamber?
Sooner or later, I will probably swap this whole thing out for a fuel cell.
Old 06-25-2013, 04:52 AM
Smoove1010
Smoove1010's Avatar
As noted above, check that short hose between the fuel tank and fuel pump under the car. Mine was covered in braided cloth, and always appeared dry when I looked at it, but I found that it was wet to the touch. Replacing that fixed the ever-present fuel smell in my garage. The old one was in an advanced state of decay, and if that line goes bad, your tank will drain itself all over your garage floor.
Old 06-26-2013, 01:46 PM
