-   -   MSD install, quick question (http://forums.pelicanparts.com/porsche-911-technical-forum/75814-msd-install-quick-question.html)
A Quiet Boom 07-27-2002 06:51 PM
Intalling and MSD 6al onto a carb converted 3.0SC engine. Two quick questions. On the coil it's marked A and B which is + and - ? Is A + and B - ? As far as the distributer goes it has a shielded type wire is the core + and the shield - or the other way around? I wired enrything up so I could switch them if necessary but I'd like to know for sure before I try to start it.
A Quiet Boom 07-27-2002 09:45 PM
Problem solved thanks to emcon5 ;)
I had both sets backwards. B goes to +, A goes to -. The shield is + and the core is -.
Thanks again
