What's the difference? (pre-74 question)
Between:
Front Caliper Rebuild Kit, Steel M, 911/912 (1965-73) A-351-964-11 $16.50 Front Caliper Rebuild Kit, Alloy S, 911 (1969-74) A-351-998-00 $27.40 Is the cheaper one for 911T and 912 only? I have emailed Pelican but am awaiting a response ![]() My dad is taking a trip down to Pelican in Redondo as they are vacation in Marina Del Rey and is fixing us up with some parts for the 911. He is looking forward to taking a look at the fabled Pelican Parts - sure is a long way from home! Our E is due a brake overhaul and all the calipers are going to be rebuilt and the master cylinder replaced. Any other suggestions? |
Home of the Whopper
Measure the bolt spacing on the front calipers. If they are 3" you have the steel calipers. If they are 3.5" you have the alloy calipers.
While you're redoing the brake calipers you may as well replace all the brake lines as well. Have fun! BK |
Phil - they are two different caliper types - the S type is aluminum (rare, expensive and desirable) the M is stock for most early cars.
Get the kit that matches part number of your caliper. You might consider fresh rotors, stainless steel brake lines, and fresh Ate Blue brake fluid. Depending upon miles and project complexity, it's easier to replace tie rods with turbo tie rod kit (check it out Pelican's catalog and 101 projects) when doing brakes. Also a good time to clean, adjust, and repack wheel bearings. Have fun
Scott |
Well I'll just order the cheaper ones then - my parents will be airborne now heading for LAX so I can't get my Dad to check the size and I am not at home.
We have replaced the brake lines recently, but the rotors (discs for British English ![]() I'll have a look in my 101 projects about the turbo tie rods. $129 seems reasonable. |
Author of "101 Projects"
Easiest way to tell is with a magnet...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
I have no way of knowing. The car and me are 220 miles apart! I take it the steel one is the most likely for a '72 E?
My 69S has the aluminum calipers...and the first thing I noticed is that they are one piece units.
They do not come apart at the normal split line (creating 2 halves). I hope this helps. Bob
Bob Hutson |
Phil,
I believe the Sportomatic cars got the 'S' brakes because of reduced engine braking with the torque converter.
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
Early_S_Man is correct - according to the parts manual, the '72 E Spotomatics received S brakes. Lucky you!
1972 911T Coupe |
That is impressive! I did not know that, Warren amazes again with an unparalled depth of knowledge. Thanks!
My T with S suspension came with S calipers (they're not-magnet-sticky, anyhow).
Was this an option? Is there a source to find out all the 1973 T options available? |
One more question. Do I need the brake pad retainer kits? They look quite expensive for what they are. How easy is it to re-use the exisiting retainers?
911 Brake Pad Retainer Kit, rear (1969-83) C-352-951-00 $34.60 |
Phil,
Usually the old hardware cleans up just fine and can be reused.
Friend of Warren
Kurt V No more Porsches, but a revolving number of motorcycles. |
