ianreiddc's Avatar
Why would owner remove the AC belt??
I am a newbie that's in the process of looking for a sharp looking and solid 911. I have viewed a few online that have pictures of the engine missing the AC belt. What would cause a owner to remove the AC belt?
If she looks good ride her. Whether it's on the highway or in the bed, but always remember to be safe and buckle up!
Old 07-28-2002, 09:15 AM
D idn't E arn I t
RANDY P's Avatar
seized compressor....
AOC/Hogg 2028
Old 07-28-2002, 09:18 AM
one of gods prototypes
bell's Avatar
yep.....my comp was siezed when i bought it and the owner left the belt on, another sign of a siezed comp is belt "shavings/debris" in the corner of the engine bay.
Brought to you by Carl's Jr.
Old 07-28-2002, 09:54 AM
nostatic's Avatar
Be very careful with "conversion" cars too. You have to wonder about how well the aftermarket parts were hung, and what might have prompted the change (ie an accident).
Old 07-28-2002, 10:19 AM
Chuck Moreland's Avatar
It may not be seized up. Removing the belt frees up a couple of HP. Reduced friction.
Chuck Moreland - elephantracing.com - vonnen.com
don911's Avatar
I removed my AC belt to free up some HP. I didn't actually notice any more HP, but I was told it frees up some.
Don
24 Cayman GTS - GT Silver
23 Cayman GTS - Arctic Grey - Sold
97 993 Coupe - Arctic/Black - Sold
13 991 Coupe - Platinum/Black - Sold, 87 911 Coupe - Venetian Blue
Old 07-28-2002, 11:06 AM
HP Junkie
When I bought my 90 C2 last year, the A/C belt was missing. I replaced the belt and with a few ounces of freon the A/C works fine.
You may want to have the owner replace the belt to make sure the compressor isn't seized, if you find one you want to buy.
Gary
Old 07-28-2002, 11:28 AM
Put one on and you'll know. It doesn't make a difference
Old 07-28-2002, 01:16 PM
Go Gators!
s2per's Avatar
One last consideration. I take my a/c belt off before I go to the track with my car...JUST IN CASE I lose the main fan belt. It happened once and I was glad the a/c belt was out of the way when installing (Ouch!) the new (Man that's hot!) fan belt. Saves quite a few minutes; important when you're running between your car and a student's!
Timothy Stoops
Air '62 356 B-‘86 911 Cab
H2O '12 Cayenne
Old 07-28-2002, 05:41 PM
Author of "101 Projects"
Wayne 962's Avatar
Removing the belt really doesn't free up any more HP. That's because the belt turning the compressor clutch when it's not on really doesn't use any energy. You might feel a slight difference, but I doubt that you would get more performance than simply removing the weight of your spare tire from the trunk...
-Wayne
Old 07-29-2002, 08:16 PM
Lothar's Avatar
I bought a car earlier in the year that had the compressor belt removed. The PO told me that it was to free up HP. I knew damned well that the A/C just didn't work for whatever reason. I didn't care because I removed the whole damned mess two months later. The old compressor can't be rebuilt anymore anyway. I don't believe that removing the belt when the compressor is not engaged would make much of a difference in performance. However, removal of: compressor, evaporator, fan, condensors, dryer/receiver and all hoses made a hell of a difference in the form of about 150 lbs. of weight.
Granted, it depends on the intended use of he vehicle.
Lothar of the Hill People Gruppe B #33
The Founders would vomit at the sight of the government that the People's lack of vigilance has permitted to take hold.
Old 07-29-2002, 08:18 PM
deltajetfixer's Avatar
Question
I guess in your total weight savings you're also counting your 100 pound girlfriend/wife who won't ride in the now, hot car, anymore?
Interesting strategy...
1995 C2 w/Tiptronic, Stongard, HID's
Old 07-30-2002, 05:00 AM
Senior Member
Hello
Driving the AC belt doesn´t need much power. If you engage the magnet clutch on the compressor you loose power.
Removing the belt from a non working system makes aminatince easier and lowers the risk that a neglet AC belt can crack and snap the fanbelt.
Also early 911 didn´t had a underpressure cout out device so you gould run the compressor even withot pressure and oil in the system.
Grüsse
Old 07-30-2002, 06:37 AM
boyo's Avatar
My car had the A/C belt removed when I test drove it, the owner insisted it was for HP savings. When he delivered it, he'd installed a belt and the A/C actually worked! You never know.
-Boyo
'48 Willys CJ-2A / '55.1 Chevy 3600 / '66 Austin-Healey 3000 / '72 Porsche 911T
Old 07-30-2002, 07:30 AM
For even more AC information, on my car (89 coupe), the full open sensor in the throttle body shuts off the compressor on hard accelerator. I removed the compressor, hoses and top condensor in my car as will soon remove everything else.
Old 07-30-2002, 07:35 AM
