steely's Avatar
Outer boot (for shifter in tunnel)
Highly technical question here....
It looks like I am missing an outer and inner boot at the rear of the tunnel.
Stupid question are these boots worth replacing?
Will I have to remove the shift linkage from behind the tunnel ? (pls say no)
Looks like the PO removed it fer some reason
I am hoping to effectively stop the cold air that is wooshing in the cab from the E-brake boot. Targa actually likes the cold, but I'd rather not have it blowing on my shifting hand.
Thanks!
no boot
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 12-16-2010, 08:39 PM
steely's Avatar
Oops - I posted the incorrect part. I need the "sealing sleeve", and there is no inner boot. Item 20 on the right.
Dan
Venetian Blue
Old 12-16-2010, 08:53 PM
AutoBahned
RWebb's Avatar
yes, I think they are worth it if you drive on the street.
of course, there are people who don't even seal the top strut mounts b/c it doesn't look as pretty, so maybe I (and the engineers at Porsche who designed the cars) are off base
Old 12-16-2010, 09:13 PM
lin7310948's Avatar
i use a soft closed cell foam ..just cut a proper sized piece and wrap around the shifter rod and stuff to in the opening. works fine for me. dont usually drive the car in wet weather but it keeps it dry if i do and no cold air! too bad CV joints arrent that easy to enclose!
69 bronco..... 91 mustang ssp santa clara county sheriff's office ...2017 focus rs tuned on 93 400 chp
Old 12-17-2010, 03:53 AM
Targa Time's Avatar
Dont you get a lot of road dust on the shift linkage and in the tunnel without it? It looks like it would be a easy repair.
Old 12-17-2010, 05:25 AM
KTL KTL is online now
Schleprock
KTL's Avatar
The shift linkage beyond the tunnel is a piece of cake to remove. There's a shoulder bolt in the alloy coupler that you remove and voila', you can install your missing boot. No readjustment of the shifter is necessary, as the bolt can only fall into one position because there's a machined hole in the trans. shift shaft that the bolt threads into.
I'd put that boot on there. Keeps crud out of the tunnel. My racecar was missing the boot for my 915 trans and there was all kinds of debris in the tunnel (as well as some gear oil on account of a leaky shift shaft seal). Your G50 is slightly different and gear oil spillage is less likely due to the shaft seal and coupler design. But the debris issue still applies.
Also note that you have a big o-ring flopping around on your shift shaft. It's a makeshift repair prompted by a Porsche parts reference manual tech tip from the 74-89 book, which is probably a shortened version of a formally issued factory tech bulletin:
On 1987-88 model 911's which have a rattle noise coming from teh shift rod, the installation of a rubber o-ring on the shift rod may help eliminate the noise. Install as follows:
1. Remove shift rod access plate
2. With shift lever in neutral, disconnect from shift rod from coupling.
3. Move shift lever in 3rd gear position and slide rubber o-ring (p/n 999 701 969 40) over front shift rod
4. Reconnect shift coupling
5. With shift lever in neutral, slightly tension the rubber ring with a nylon tie strap to the left side hand brake cable guide tube. The distance from the shift rod flange to the o-ring should be approx. 100mm.
6. Reinstall access plate. Road test car. If rattle noise is still audible, increase tension on the rubber o-ring slightly
Pretty cheesy, eh? No need to buy the Porsche o-ring if anybody wants to do this quick fix. Any large o-ring from the hardware store will do.
Kevin L
'86 Carrera "Larry"
Old 12-17-2010, 07:04 AM
Dan:
I live pretty close to you(relatively). If you would like, we can install your boot in my heated garage. I have dropped my engine a lot, so I know exactly what Kevin is describing above. It will take about a half hour to forty-five minutes to install.
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 12-17-2010, 07:41 AM
steely's Avatar
Thanks for the replies guys.
lin7310948 I'd considered the foam idea, but now think I'll opt for the part since it sounds like it is worth it.
Yeah, she & I are just street (RWebb).
Targa Time - I wondered the same thing - didn't seem too bad in there, but I really didn't notice the air flow (and linked the dirt suction factor) until I started driving her this winter.
Kevin - the pic (with O ring is from 2 yrs ago when I was doing the front shift bushings and decided to inspect under the rear door. The ring had me stymied as to it's purpose - cheesy is right (chuckle). I really don't recall offhand if I removed it or not at the time.
Chris - thanks very much for your gracious offer. I'm in Maple Glen (Horsham twp) and work at LM in VF/KoP. (closer to you). Mind if I ping/PM you after the holidays/place the order?
Thanks all
Dan
Venetian Blue
Old 12-17-2010, 02:19 PM
m110's Avatar
Mine was missing too (many mechanics toss it I've heard). Easy to replace, I didn't notice any noise difference but seems like a good I idea to seal out the elements. 1 bolt, $35 or so.
1988 Carrera Coupe
Old 12-17-2010, 02:27 PM
kodioneill's Avatar
AH Ha That's how the air is getting into the front compartment and through the dash? I've tried to adjust hood. I thought it was a leak through the A/C condenser fan. Now I know. Sorry for the thread hijack.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 12-21-2010, 10:17 AM
AutoBahned
RWebb's Avatar
check the front lip seals also
Old 12-21-2010, 01:22 PM
DW SD's Avatar
Ouch. That stings! Still hanging onto this from the other thread?
Porsche made their cars, like most car companies for a global climates. Some know the climate to which they'll expose their cars and plan accordingly.
I'd run the shifter boots just to keep dust out of the tunnel.
Doug
1971 RSR - interpretation
Old 12-21-2010, 01:54 PM
dshepp806's Avatar
Doug
+1.
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 12-21-2010, 02:01 PM
Does anyone know exactly how far in/out the rubber sleeve/boot needs to be? I'm thinking it should just be inside the opening to the engine bay. Is it supposed to be pulled over the area in the engine bay that has the bolt?
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 05-25-2024, 03:34 PM
I came by this thread searching to see how putting on the shift coupler boot is done. I tried for quite a while with the transmission mount installed with no luck. So, with the transmission supported, I removed the mount to get much better access. I managed to get the rear of the boot over the lip on the transmission. There's no real way to get it on the lip with the transmission mount on that I can see.
I'm adding two photos showing how the boot should look after installation for anyone else searching the interwebs for how to do it.
1987 Carrera Cabriolet in Cassis Red Metallic
Old 11-02-2025, 06:31 PM
