-   -   Installed cat by-pass today... (http://forums.pelicanparts.com/porsche-911-technical-forum/75883-installed-cat-pass-today.html)
Kurt B 07-29-2002 06:42 PM
Originally posted by PDACPA
Kurt - You talking about the sound deadening pad under the rear window? Yanked mine a few months ago as it was falling apart. No difference in sound in the car and it does seem more spacious in the engine compartment. Never thought that it gave more air.
My 3 yr old wont have me yanking the rear seats! I need some other weight saving techniques!
I took the one in the engine compartment out, the one below the rear window, and all the material beneath the seats..just the padding alone is 35 or 40 lbs total.
kepperly 07-30-2002 08:17 AM
ON MY 87 CARRERA SLANT I,VE INSTALLED AN AUTHORITY CHIP,
VERTEX CONE FILTER , CAT BYPASS, AND BURSCH MUFFLER AND
ABSOLUTLY LOVE THE PERFORMANCE. IN A CABRIOLET THE OLD
B AND B TWIN 4" EXHAUST WOULD POP AND CRACK AT SHIFT POINTS AND DROAN AT A STEADY 70MPH, NOW THE CAR SOUNDS LIKE A PORSCHE AGAIN AND DOES ROAR WHEN PRESSED. AND IS
QUIET WHEN DRIVEN CONSERVATIVLY.
KEITH
PDACPA 07-30-2002 08:53 AM
Kurt - I did not think about that pad under the rear deck where the speakers are! Damn just had that undone putting in new rears.
Did you toss the carpet and mats? my metal floors look a bit beat up to go without
Kurt B 07-30-2002 09:29 AM
I put the carpet back. You take the carpet out, take the padding beneath the seats out (pretty darn heavy), then put the carpet back in, and put the seats in it...it's very easy..I can post a pic of what it looks like, basically the same as it does now, but the seats setting a bit lower (and they won't line up with seat backs as it changes their position too)
It looks exactly like it did before minus the seat backs...it's just lighter and louder :)
nhromyak 07-30-2002 10:00 AM
I just had the cat reinstalled for smog...
My popping almost went away.
My bypass doesn't QUITE fit. I ended up doubling up on the bypass to muffler gaskets. That helped quite a bit.
I also noticed when putting the cat back on.. the engine is MUCH smoother in accelerating. Not sure if it is slower.. but it is smoother.
I have a weltmeister chip. Stock intake and filter. I also have K&N filter, but no noticable difference.
I wonder if the Cone filters are simply getting cooler air intake.
I was contemplating doing what WIDEBODY (and some other SC guy on here) has done with the cold air intake.
Thoughts anyone?
weber92037 07-30-2002 11:54 AM
The cat-pipe conversions sound interesting and worth while. How does this affect the bi-annual emissions testing requirements in California?
bornrich 07-30-2002 12:37 PM
Yea, it does if the guy (or gal) doing the visual knows what he is looking at. However the pre-muffler look similar to a cat and can pass as long as the rest of the test passes.
A side note: can the heat shield be installed with the pre-muffler? The reaon I ask it will help in the illusion that it is a cat not a by pass.
PDACPA 07-30-2002 01:31 PM
Born - George (cant think of his Pelican nick) said it has no way to attach the cat cover plate. I agree with it confusing the visual people.
