Dash Signal Lights
Hello all,
My front and rear exterior signal lights work fine but the dash indicators do not light as well as no clicking sound is apparent when the indicators are activated. Does this mean that I have a problem with the emergency / turn signal relay ? Do I need to remove the Fuel/Oil dial to replace it ? If so how can I do this without damaging the dash ? :confused: Thanks, Peter |
If it's in the same place as my 79 you can access it from the trunk. The gauges are just pressed into the dash (the rubber holds them in) and can be carefully pried out.
Grab the dial with your fingers of steel and pull it toward you, maybe the bulbs are gone and you can not hear the clicking relay because of the nice exhaust noise?
