47silver's Avatar
1976 2.7l motor in a 72T
since no one wants to buy the 76 motor i have for sale, i am thinking of using it in my sons 72T while we work on his 2.4.
Am in right in thinking that we need to:
1. use a cis fuel pump.
2. add wiring for the cold start valve.
i think that 76 uses an aav so we would not need to hook up the hand throttle.
is it that easy?
1975 911S Targa
Silver Anniversary Edition
Old 07-04-2013, 08:16 PM
Send a message via Skype™ to Porboynz
Connecting the oil system will be interesting. You will need to the check compatibility of engine loom plugs, otherwise the fuel pump is about it, the hand throttle is a use it if you need it item, otherwise non intrusive.
1972 911T Coupe with a '73E MFI engine and 'S' pistons
10 year resto mostly completed, in original Albert Blue.
***If only I didn't know now what I didn't know then***
Old 07-04-2013, 09:40 PM
