1974 911 w/ 83 SC engine
Alternative to the traditional belly pan?
The belly pan on my '74 is pretty ragged. I looked here for a new one and they have to be special shipped from Germany and that takes a while. So what are the other options out there for belly pans? I was surprised to see Rennline doesn't have something. Anybody using a belly pan alternative they recommend?
Checked the net...found Resoration Design...
Front half...P218....$220 Back half....P219...$220 How's that? Bob
Bob Hutson |
300hp 1800lbs is the goal
I think he means the protective (and removable) shield over the steering rack/fuel pump.
There are aluminum/composite ones I see on the forums from time to time. They are usually one offs tho.....
The '66 912 Bastardization project has begun. Note to PO's: LAY OFF THE FREAKING BONDO!!!! The science was settled: Earth was flat. Galileo : Flat Earth denier.
Mine looked like one of my PO's went off-roading. I banged it as flat as possible, and sent it for a nice powder coat - she looks great now.
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue |
Yeah, the removable pan under the front. I'm surprised no one makes a good aftermarket replacement. Guess I will look into beating mine back into shape or fabricate something. Upside to that is there's got to be 2lbs to shave off there. Haha
It's the lowest point on the car, on the front..... not really some place you need to shave weight
When I did my suspension refresh two years ago I removed it...have never put it back on but it looks brand new with the new high temp paint.
1986 3.2 Carrera |
I think about it but thats about it...So far, no issues but I guess it only takes once. I actually though about, a year or so ago, making a fiberglass version but never did.
1986 3.2 Carrera |
