Just an update. Tonite after dinner, I took her for a nice long drive. I haven't been able to take her to work because of the constant threat of thunder storms this week. I drove her for about 40 minutes. She averaged around 210 F (99 C) peaking at one point at 215 F (102 C). This is while still pretty hot and humid out, about 85 F (29.5 C). Looks like a little progress before redoing the dwell (larger) and ignition timing (at 6000 rpm). That said, however, power was improved, especially on start up.
Problems with this system include: 1) Pitted breaker points 2) Condenser over saturation 3) Worn breaker cam 4) Worn Dizzy shaft bearing 5) Binding mechanical advance weights and springs 6) Degraded vacuum retard dashpot (vacuum hoses) 7) Internal voltage leak between the secondary and primary winding of the coil 8) Degraded(carbon tracked)coil, rotor, dist cap and secondary ignition wires 9) Poor primary voltage supply from ignition switch/fuse box 10) Poor distributor/breaker plate ground There are many more examples of breaker system failure and some defy reason. Some of the popular diagnostic practices include: 1) Spraying water on high voltage (secondary ignition) components while engine is running. 2) Applying different 12 volt supply to coil's positive connection 3) Disconnecting CDI unit 4)Installing a redundant ground to distributor housing 5) Using a strong magnet to diagnose coil break down |
| All times are GMT -8. The time now is 02:39 PM. |
