-   -   Airbox replacement, How long should it take? (http://forums.pelicanparts.com/porsche-911-technical-forum/759601-airbox-replacement-how-long-should-take.html)
matt gineo 07-06-2013 03:27 PM
Just wondering how long it should take an experienced P- Mechanic to replace an Airbox in a 1976 2.7?
http://forums.pelicanparts.com/uploa...1373149621.jpg
thumbdoctor 07-06-2013 03:55 PM
Not an experienced Porsche dealer tech but I can replace the air box, tube rubbers and intake tube gaskets in a bout 4 hours.
matt gineo 07-06-2013 04:26 PM
Thank you Thumb Doctor, do you do a partial engine drop when you swap out the Airbox?
kodioneill 07-07-2013 06:00 AM
With a partial drop (recommended) 4-5 hours.
matt gineo 07-07-2013 06:20 AM
Great, Thank you
Peter Zimmermann 07-07-2013 07:44 AM
Matt; figure about 8 hours with either a partial or complete engine drop. There are always a few little things that need attention (throttle linkage console bushings, injector o-rings, thermostat o-ring, oil pressure switch, etc.), and a '76 has automatic cold start that makes the job more difficult near cylinder #6.
