Jacking up a 912 same as 911?
Can you jack up a 912 under the engine with a floor jack and a piece of wood/rubber like you do a 911? Is the sump strong on the 4 like the 6?
Thanks, David |
I'd recommend using the jack points and adapter for your floor jack, rather than using the engine and motor mounts to bear the entire weight of the car.
http://petry.org/pics/jacktool.jpg |
There is some quick maintenance needed by my brother before the weekend and he does not own a jack pad - hence the question.
The chassis is the same* (like 99.9% the same, obviously the motor mounts differ).
This image was posted up in a thread not too long ago. X = Jack points 0 = Jack Stand Support Points http://forums.pelicanparts.com/uploa...1373316387.jpg |
So then the motor/sump will NOT support lifting the car to place jack stands?
Sorry - I knew it was oft discussed about 911's, just wasn't sure about a 912.
FYI in his tool kit there should be a piece that inserts into the side jack point location. The piece is made for use with the factory scissor jack, but might could be used with the floor jack in a pinch. Nevermind, I was horribly wrong about that, the factory jack was never supposed to seperate in the manner I described. I happen to have a broken unit and never realzsed it!
For 45 years I have jacked up my '65 912 under the sump then put jack stands under the chassis and have never had a problem, but then it does have the early "solid" engine mounts, not the later rubber-dubbers...
Frank |
| All times are GMT -8. The time now is 06:06 PM. |
