carrerarsr65
twin plug ?s
79sc 3.0 who does a reasonably priced twin plug dizzy conversion? other than doing the heads,lwr valve cvrs, what else is involved, i'm looking at running 10.5 je pistons so might as well go down the slope a little farther
Old 07-09-2013, 08:55 PM
You will need:
Twin-plug distributor (JB Racing is the best, hands-down)
Additional CD box
Additional coil
Machine heads and lower valve covers for the second plugs
Plug wire harness
At 10.5:1, you NEED it to run on pump gas.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 07-09-2013, 10:08 PM
fred cook's Avatar
Twin plug spark
An alternative would be to use a direct fire system such as the Electromotive XDi or XDi2. With one of these systems, you eliminate the distributor (no expensive caps to buy), coils, CDI boxes, etc. You will have to mount the two DFUs (direct fire units) and find a place in the cabin for the control box. The wiring is not difficult to complete and as a bonus, you will have infinitely adjustable timing controls. The cost should be similar to buying the new distributor and associated hardware.
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 07-10-2013, 03:46 AM
