jphillips-998's Avatar
Brake Pad Suggestions
Has anyone had any experience with the Carbon Metallic pads from Performance Friction Corporation's (PFC)? They are offered by OG Racing.
How do they rate compared to the Pagid Orange or others?
I am looking for a good track pad for the '74 Carrera. Running Ferodo's now and they have been overheating and feeling rather spongy. I know I need cooling ducts, but my immediate need is for pads.
Suggestions/recommendations?
Jeff
'04 Cayenne S Hauler
'98 993 Cab
'74 Euro Carrera - SOLD
'91 944S2 Track Car
Old 07-30-2002, 05:36 AM
I used to run PF90's and they worked great. However, 90's have been discontinued and replaced by the PF97. Upon switching to the 97's I, and several guys I race with that also switched, started experiencing frequent caliper failures. I have had two fronts fail. Two other guys running mid 80's Carrera's have had multiple front and rear caliper failures. In one instance, three of 4 calipers failed simultaneously. We all have ducted brakes. In all cases, the outer end of the caliper failed. PF has admitted to having similar feedback on the 97's, especially from Mustang drivers. We run mainly in Texas and it's hot as hell at most of the tracks we run at.
The weird thing is 75% of the time they fail after the event with the car sitting on the trailer.
I have purchased a set of Pagid Orange and I plan on trying those next time out. Also, the problems got so bad at the Texas Motor Speedway club race that several of us also switched to Castrol SRF.
1973 911T Sepia Brown MFI
1986 Carrera Meteor Gray Metallic
Old 07-30-2002, 06:26 AM
WOW! Thanks for the feedback! Enough said. I'll be ordering the Pagid Orange's today.
Thanks.
Jeff
'98 993 Cab
'91 944S2 Track Car
Old 07-30-2002, 07:03 AM
KenH
Guest
Posts: n/a
Orange Pads & ATI Blue brake fluid should stop the problems you describe.
Ken
Old 07-30-2002, 08:04 AM
I'm curious about the mode of the caliper failures.
Old 07-30-2002, 09:39 AM
Super Moderator
cstreit's Avatar
Same here, just what exactly is caliper failure? Overheating or catostrophic caliper part failure?
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 07-30-2002, 09:43 AM
