-   -   Timing Light Question(s) (http://forums.pelicanparts.com/porsche-911-technical-forum/76020-timing-light-question-s.html)
MAS956 07-30-2002 07:56 AM
I recently put a new distributor in my '82 SC and set the timing statically. The car runs fine and passed CA Smog with flying colors, however I am noticing a slight pinging under load in the 3-4k rpm range and am wondering if my timing is off slightly.
I am trying to use a Sears timing light that someone gave to me which I have never seen work. I've got power at the rear fuse panel, plenty of good grounds and have the pick-up wire attached to #1 spark plug wire. I'm getting no light from the timing light when I press the trigger (yes, the engine's running).
Could I have the pick-up placed incorrectly - the Smog guy mentioned that he was having problems with the signal through the braided plug wires? How about the bulb in the light - do those fail on 20 year old units? Is the bulb replaceable or do I just need to bite the bullet and buy a new light?
Thanks for the suggestions.
KenH 07-30-2002 07:59 AM
Place the pick-up over the un-shieled part of the wire.
Ken
MAS956 07-30-2002 08:06 AM
Thanks Ken,
I've tried the pick-up on both ends of the wire as close to the connector as possible, but don't know if that's bare wire or not. Should I be rolling back the rubber boots or should signal be fine wth the pick-up around the boot?
Thanks,
Early_S_Man 07-30-2002 08:07 AM
Mark,
You won't be able to get a good trigger signal over the braid, so be sure you are right next to the distributor, and slide the braid out a bit further if necessary to get access to unshielded wire on #1.
Have you considered testing the timing light on another vehicle?
KenH 07-30-2002 08:10 AM
Should be OK if there is no shielding. The braid of the shield should be very visible. Try the light on a car without shieled wire to see if it functions.
Ken
MAS956 07-30-2002 08:17 AM
Thanks guys,
I'll try the light on another vehicle before I tear into the timing light to see if there are any user-serviceable parts!!!! It won't be nearly as much fun that way, though.....
