Brake line pic under this cover please?
Could someone be so kind to send me a pic of what's under this hard cardboard cover on their '87-'89 Carrera please? It's located in the frunk right next to the brake booster assembly. Mine apparently isn't stock but I can't seem to tell from the part catalog or Pelican replacement brake parts what really needs to be here. Thanks!
'87 911 Carrera Coupe (go fast, small parts / small kids hauler)
'04 Toyota Land Cruiser (go slow, go anywhere, haul everything, the "AntiPrius")
Old 07-12-2013, 04:51 PM
steely's Avatar
Hope this helps.
I had a leak from the Master cylinder that I was investigating and took this pic.
I think it is a pressure regulator for the rear. interesting that you have 2.
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 07-12-2013, 07:22 PM
Actually I think I have none now. Mine appears to have been removed and the spiral piece and fittings are just there to complete the circuit.
Old 07-12-2013, 07:34 PM
Northern Motorhead
wildcat077's Avatar
That is where your OEM brake bias valve goes ... it seems somebody added a home made one for whatever reason in order to alter the factory settings !
You might want to look further into this as it might compromise your car's factory front/rear brake bias.
Most people with brake upgrades just gut the interior of the valve but adding another inline restrictor or valve of some sort is NOT a good thing ...
Cheers
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 07-12-2013, 07:48 PM
