JuiceMan's Avatar
Question Painting Fuchs Center Cap Black. What to use?
Ok I purchased 4 nice FUCHs wheels used. One of them is missing a center cap so I just ordered one from Pelican.
Problem is my center caps are black and 3-Prong seems as if Porsche never made Black 3-Prong caps. Sam @ Pelican said most people paint them with Krylon Flat Black.
Anyone here have experience with this matter? What paint did you use?
Thanks,
Dustin
Old 08-27-2001, 04:31 PM
RETIRED
Joe Bob's Avatar
Post
You have the early style Fuchs. They came on 914/6s as well. Nothing wrong with them, just not very wide. They changed the cap style in the early 70s...
I have used black krylon and sprayed them all so that they would be a uniform color. They are a little easier to do if dismounted and w/o tires. Just take your time and mask them off and rough up the surface with emory cloth.
Old 08-27-2001, 05:10 PM
Post
I just had mine powder coated. cost 5 bucks a piece. I had them done in a semi gloss which realy looks like a satin.
Old 08-27-2001, 06:28 PM
Team California
speeder's Avatar
Post
I like the powdercoating idea if you can get the right sheen. I wanted my fuchs to look original and experimented with spray cans, the results: semi-gloss= nice but too shiny; flat was real close; rustoleum satin black= perfect!
Old 08-27-2001, 06:57 PM
autobonrun's Avatar
Thumbs up
I painted mine several years ago using a gloss paint. It turned out very good. I painted the center cap emblem by hand. About every two years I retouch it. Saves quite a bit over purchasing the painted center caps.
Old 08-27-2001, 07:24 PM
Eric Coffey's Avatar
If you want the paint to match the rest of the factory black trim, get some Wurth "satin black trim" paint in a rattle can. This is what the factory used, and is high quality stuff. Just make sure you rough up the finish (Scotch-brite pad is perfect)before applying any coats. They also make all sorts of other top-notch quality "spray can" products. You can call them (800-346-4198) for a local distributor, or go to their website at: www.wurthwest.com
-Eric
[This message has been edited by freefly (edited 08-27-2001).]
Old 08-27-2001, 08:02 PM
stray15's Avatar
Send a message via AIM to stray15
Post
If you want to paint the center cap crests, get some paint markers at the local art store. I did mine and they look really good.
Porsche, through and through
Tim
'83 944
My Photo Page
My Home Page
Old 08-28-2001, 06:47 AM
