Is it normal for the pressure and level gauge to "pop" around?
The movements they have aren't fluid. Both the oil pressure and level gauge twitch, especially the pressure gauge. I'll be sitting at idle and it'll hover around 1.5 but then all of a sudden twitch to over two. I'd think the movements would be pretty fluid, but maybe this is normal? Car has 200k on it, and oil pressure sender was replaced at 150k (2004) during the top end rebuild.
88 Carrera - Venetian Blue
2002 Audi S4 Avant (KIA)
Old 04-09-2013, 07:09 AM
muck-raker
kidrock's Avatar
My Druck gauge flicks and jumps just as you described...not much at all, just a bit. I had to replace the pressure sender unit recently and it still does it. I'm sure it's normal, as long as it's not jumping radically. My sender works great...when the engine is running at normal operating temps and parked on level ground, the gauge matches exactly the level on my dipstick. That's the most important thing.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 04-09-2013, 08:50 AM
RETIRED
Joe Bob's Avatar
Does the pressure gauge twitch in time to the rpms? If not could be a sender continuity issue. If it twitches WITH rpms at idle, could be a vacuum leak.
The oil level gauge lies.....the dip stick is the final authority.
2012 ML350 3.0 Turbo Diesel
Old 04-09-2013, 08:55 AM
My oil level gauge sits pretty still when level, idle, and it has refilled, but it still moves around a bit. More than what I'd think for a still oil tank, but sounds like it's pretty normal. It's accurate, though, with my dipstick. The oil pressure gauge is generally accurate, but even at idle when the RPMs aren't changing, it twitches around. Sometimes it'll be at 1, and then twitch to 2, and then back to one - despite a steady idle at the engine.
Old 04-09-2013, 09:02 AM
Hunt3R's Avatar
My oil pressure gauge used to do this, I thought perhaps it was just normal. Then I found that the vacuum hose connecting the fuel pressure regulator and damper has a T-connector where it plugs into the back of the throttle body and it wasn't connected. And there was another small vacuum hose that plugs in right above it and was disconnected too, just hanging there. After I reconnected them a side-effect seems to be that my oil pressure gauge is no longer twitchy.
Old 04-10-2013, 04:29 AM
You could try cleaning the connections. That made improvements to tha action of my guages.
1986 3.2 to 3.4 conversion
Old 04-10-2013, 05:11 AM
RZG RZG is offline
Where is the druck pressure guage terminals that could be loose in the engine compartment,thanx.
Old 07-30-2013, 10:28 AM
Go-Kart Mozart
JAR0023's Avatar
Need help on wiring 1987 911
86 Carrera
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken
Old 07-30-2013, 10:35 AM
we could try and clean the piviots and dampen the movment...
Buz
Seattlespeedometer.com
Old 07-30-2013, 11:17 AM
Functionista
manbridge 74's Avatar
Re: oil pressure gauge.
I noticed that someone previous had replaced the 'faston' connector at the gauge with aluminum instead of the normal brass kind. Needle swung from one extreme to the other until I cleaned it up some.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 07-30-2013, 01:03 PM
